6 speed won't go into reverse even with Solenoid removed
Hey guys,
My car decided it wasn't going to go into reverse all of a sudden. I was told that it must be a problem with the reverse solenoid. The solenoid is removed and seems to be operating like it should. Even with it removed, though, I can not put the transmission into reverse. What would cause that all of a sudden? Would removal of the solenoid allow it to go into reverse, or is my thinking incorrect? Is reverse synchronized? Maybe the synchro is out? Please help, I am desperate and broke. Thanks.
Hey guys,
Connector was checked for voltage and solenoid was checked for correct actuation after removal. Figured it might be locked up that is why I removed first. Even out I still have no reverse so that point if really moot.
Sounds like you have it under control.
But after pulling the solenoid, shouldn't I be able to shift into reverse? I thought that would at least make it so it could go in. I can shift into any gear but reverse. What would cause that? Anyone? PLEASE.
At what stage of going into reverse do you have a problem, in other words can you get over all the way to the right to where just going up would engage reverse, or do you end up in 5th pushing forward when you've moved as far right as possible?
If it was just a bad solenoid, and even if the lockout somehow still works when the solenoid is removed (no idea, wouldn't have thought it did) you should still be able to muscle the shifter all the way to right where it should slide up into reverse with minimal effort going up.
Guess it could be shifter alignment issues but I'd think you'd have problems w/ other gears too. Doesn't sound good...
Don't put the key in the ignition and try to put it into reverse ? If you can do it, then your problem is electrical, if not it is mechanical
The fact that I can shift my car into reverse without the battery installed would lead me to believe that energized = locked out. Hence removing it should have the desired (though unsafe) effect. Can you get into reverse when the engine isn't running? If so, that would certainly point at the synchro.
Reverse Inhibit Description and Operation
The reverse inhibit solenoid is a safety feature which prevents an inadvertent shift into reverse at speeds above 5 kp/h (3 mph). The system consist of the following components:
The powertrain control module (PCM).
The reverse inhibit solenoid.
With the ignition ON battery voltage is supplied directly to the reverse inhibit solenoid. At forward speeds above 5 kp/h (3 mph) the PCM grounds the control circuit of the reverse inhibit solenoid. This energizes the solenoid and mechanically blocks the shift lever from going into the REVERSE position.
Resident moron
I vote on rebuild too. Even with the the solenoid engaged you can still muscle the shifter over into reverse, it's just harder to do. If you can't move it over to reverse at all, even with the solenoid removed and/or the engine off, you have a serious mechanical issue.
Dope
Dope
Dope
Dope
If you can get it into reverse with the car off, START the car (still in reverse) and let the clutch out and see if your truly in reverse or not. This would rule out the trans/shifter and point at the lockout.
Solenoid is out of the tranny. Engine is not running. I still can not get it into reverse. I don't know how the synchro would stop it then. It is like something is physically blocking it. I don't understand how this would happen, though, all of a sudden. It worked one day, the next it doesn't. I am hoping maybe there is an issue with the shifter, or maybe linkage issues. I don't know, this is getting frustrating and expensive. Thanks for the help guys.
Try 1 other thing, there are times when many have a hard time getting the car in reverse normally. Try pushing the car back a few inches while trying to get it into reverse. Last thing to try before the trans comes out.
