2001 Door Lock Module Question
Old 05-20-2010, 06:53 AM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Default 2001 Door Lock Module Question
The FOB will no longer unlock or lock the door on the drivers side. I have to lock that door using my key. The window function is fine. It goes up/down with no problem. All other aspects of the door seem to function as designed except the lock.
The passenger side door works fine with the FOB. I want to get a new module or a good used module for the DRIVERS door, BUT.
I'm confused.
I see TWO different part numbers commonly listed.
10342159
09389689
Both are "advertised" as being correct for 2000 and up C5's.
I believe that the 10342159 number is the correct one, but the other number keeps turning up, being listed as "correct".
What's the scoop?
TIA.
Chuck
Old 05-20-2010, 08:31 AM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I just fixed the same problem that you have, but in the pass. side door of my '01.
If your handy with a soldering iron, you can repair your DCM for about $5 and a couple hours of your time.
Forum member Bakersfield posted a how to do write-up about it. Here's the link to it:
http://forums.corvetteforum.com/c5-g...w-problem.html
Old 05-20-2010, 09:10 AM
Chuck Gongloff
I read that thread several times.
To be honest, I'd just as soon buy a used module and pop it in.
That's why I'm confused about the PN's. Also, I don't want to tear the door apart without the replacement in hand, as my wife drives the car almost every day.
Chuck
Old 05-20-2010, 10:33 AM
Quicksilver Vert 01
If your going to the trouble of taking the door panel apart, at least put a new DCM in it. A used module will probably have, or very soon have, the the same relay problem that you now have in yours.
I do know that the modules are each made specific for the LH and RH doors. Make sure you buy a DCM for an '01-'04 driver side door.
Old 05-20-2010, 02:11 PM
burbleflyer
burbleflyer's Avatar
St. Jude Donor '08
Mine was not the relay. It always clicked, just the lock solenoid never function. I bought a used one off a member here and popped it in. It's a bit of a finicky replacement but wasn't too hard.
Old 05-20-2010, 02:20 PM
Chuck Gongloff
10342159
09389689
What's the scoop?
TIA.
Chuck
I'm beginning to believe that the 10342159 is for "memory seats" and the 09389689 is for non memory seats.
At least some of the ads lead me to believe that. Since I'm relatively new here in Florida, I don't know any of the parts guys at the Chevy stores.
Back in Maryland, I'd just make a call. Hate to bother someone with a PN request if I have no intention to buy. That module, BTW, lists for over $400.00 You can get them new for about $280.00 or so. You can get them used for $75.00, guaranteed. I've seen several on EBAY.
Chuck
Old 05-20-2010, 06:40 PM
Bakersfield
Bakersfield's Avatar
PM to Chuck...
Old 05-20-2010, 09:20 PM
76 VETTE
76 VETTE's Avatar
My next project!
Old 05-21-2010, 08:48 AM
Chuck Gongloff
Originally Posted by Bakersfield
PM to Chuck...
PM answered.
Thanks, Dwayne. Awaiting your response.
Chuck
Old 05-24-2010, 11:07 AM
spladam74
spladam74's Avatar
@ burbleflyer.. Having the same issue with a 2000s driver door. I can hear the module click but the door lock won't always work. You replaced the lock solenoid and that cured it? Would you happen to have the part number? And where is it located? Thanks!
Old 05-24-2010, 12:35 PM
Quicksilver Vert 01
Hearing the relay click in the module does not mean that it's good.
Most module problems have been dirty or burned relay contacts, and full power is not sent to the door lock actuator.
The DCM's are located inside each door panel. Read the link to Bakersfield's write-up that I posted earlier in this thread.
Old 05-24-2010, 01:13 PM
spladam74
spladam74's Avatar
Ok thanks! It does lock and unlock sometimes. Would you suggest replacing both lock/unlock relays? And are both relays the same part number? Thanks again
Old 05-24-2010, 03:32 PM
Quicksilver Vert 01
Yes, definitely replace them both at the same time. They both are the same P/N.
Old 05-24-2010, 07:59 PM
Bakersfield
PM sent....
Old 07-03-2015, 04:01 PM
topdown01
topdown01's Avatar
Default Same Lock issue for me
I'm confused.
10342159
09389689
What's the scoop?
TIA.
Chuck
So, I had the same thing happen to me. The passenger side would not lock when using the fob or the actual lock button. I left it for about a year and finally got tired of manually locking the door. By the time I was ready to repair it today both the lock and unlock feature were not functional.
I purchased the relay from digikey. The part number I purchased was, digikey 255-1240-ND (Relay Automotive SPDT 15A 12V. I ordered 6 of them because, one they are cheap...$1.72 each, and two I was not sure if I would need 3 per side given the pictures I saw of the PCB, I thought I may have the same issue with the other side in the future...this pretty much assures me that I will not
By the way, digikey ships super fast. At my door step 2 days later and I chose standard shipping.
I had desolder wick already, iron, flux, and knife. I followed the following instructions to get the door apart:
http://www.vetteessentials.com/instr...or_handle.html
And then to replace the relay modules I followed the following instructions:
http://www.valleyvettes.ca/door_module.html
The silicone is a bit of a pain in the ***, but aside from that all is good. Takes some patience to desolder but hey, its a holiday anyway!!
Luckily, everything worked like a charm and I had it apart and back together in about 2 hours.
Thanks to everyone for all their posts regarding this issue. I am just reconfirming that these two resources are perfect to use if you have this issue.
Happy 4th of July everyone!
Old 07-03-2015, 04:05 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if you decide to buy used I have the parts out of a working 02...let me know
Old 07-03-2015, 06:29 PM
busav8or
busav8or's Avatar
Here's a variation on this apparently common problem. My passenger door lock will not lock or unlock with either the fob or the switches on the driver or passenger side. The passenger door switch, however, will both lock and unlock the driver side door as it should. I'm thinking a bad passenger side actuator since the switch is sending a good signal to the driver lock vs a dual (lock and unlock) relay failure which seems to be the major problem that occurs with these locks. What do you all think?
BTW, she's a 2003 AE 'vert if that helps!
To 2001 Door Lock Module Question
Old 07-04-2015, 04:24 AM
laurent_zo6
laurent_zo6's Avatar
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
This place will do repairs for a reasonable fee:
http://www.autoclockrepair.com/c5_corvette_electronics
Old 07-04-2015, 06:41 AM
mike_engr
mike_engr's Avatar
I second that. I did the 15A digikey resoldering last year. My passenger side would click but not actually lock. after soldering in new relays its been working great over a year.
Do the soldering yourself or find a local or mail-order tech who can do it.....
Old 07-04-2015, 10:25 AM
busav8or
busav8or's Avatar
Thanks! Sounds like cheap insurance for only about $48! I don't trust my soldering skills.
Quick Reply: 2001 Door Lock Module Question
