Old 03-06-2015, 03:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Stock C5 Ride Height?
Old 06-14-2010, 04:08 PM
flynhi
flynhi's Avatar
Default Stock C5 Ride Height?
Where can I find the stock ride height dimension - from ground to top of wheel well front and rear?
Tks.
Old 06-14-2010, 04:15 PM
lucky131969
lucky131969's Avatar
Tks.
In the service manual under Suspension "Trim Height Adjustment".
Old 06-14-2010, 04:29 PM
Mark C5
Mark C5's Avatar
St. Jude Donor '08-'09-'10
Tks.
Wheel wells are not an accurate way to measure ride height, there is too much variation vehicle to vehicle.
As lucky said, the service manual provides the proper procedures and measurements. What you are measuring is the angle of the lower control arms.
If you just want a rough idea I would suggest you go to a gathering and ask some people with stock ride height cars if they would mind you measuring. I think you will be surprised at the range you are likely to find.
Old 06-14-2010, 04:30 PM
flynhi
flynhi's Avatar
Is there an online location? - I don't have a Service Manual.
Old 06-14-2010, 04:50 PM
Mark C5
Mark C5's Avatar
Give this a try:
Perform the following before measuring the trim heights:
1. Set the tire pressures to the pressure shown on the tire placard. The tire placard is located on the driver's door.
2. Fill the fuel tank.
3. Place the front seats in the full back position.
4. Make sure the rear compartment is empty.
5. Make sure the vehicle is on a level surface, such as an alignment rack.
6. Close the doors.
7. Close the hood.
8. Close the rear compartment lid.
J and K dimensions are measured vertical to the ground. These trim heights should be within 6.4 mm (0.25 in) to be considered correct.
Measuring J Height
Important
The Real Time Damping system must be operative while taking measurements.
1. Lift the front bumper of the vehicle up approximately 38 mm (1.5 in). Gently remove hands. Let the vehicle settle.
2. Repeat this step two more times.
3. Push the front bumper down approximately 38 mm (1.5 in). Gently remove hands. Let the vehicle settle.
4. Repeat this step two more times.
5. Measure 88.9 cm (35 in.) from the center of the front wheel to the lower edge of the rocker panel.
6. Mark the spot.
7. Measure the J dimension (from the lower edge of the rocker panel to the ground). Refer to Trim Height Specifications in Wheel Alignment.
8. If the J dimension is not within specification adjust the Z height.
9. To adjust the front spring to correct the Z height. Refer to Trim Height Adjustment in Front Suspension.
Measuring K Height
Important
1. Lift the rear bumper of the vehicle up approximately 38 mm (1.5 in). Gently remove hands. Let the vehicle settle.
3. Push the rear bumper down approximately 38 mm (1.5 in). Gently remove hands. Let the vehicle settle.
5. Measure 78.7 cm (31 in.) from the center of the rear wheel to the lower edge of the rocker panel.
6. Mark the spot.
7. Measure the K dimension (from the lower edge of the rocker panel to the ground). Refer to Trim Height Specifications in Wheel Alignment.
8. If the K dimension is not within specification adjust the D height.
9. To adjust the rear spring to correct the D height. Refer to Trim Height Adjustment in Rear Suspension.
Base, FE1, FE3, FE4-----------J Height (Curb)-----------K Height (Curb)
Service Preferred--------------153 mm (6.02 in)---------158 mm (6.22 in)
Service Allowable--------------153 mm (6.02 in)---------158 mm (6.22 in)
Old 06-14-2010, 05:07 PM
AU N EGL
AU N EGL's Avatar
and fenders are never even
Good Luck
Old 06-14-2010, 05:32 PM
Mark C5
Mark C5's Avatar
Originally Posted by 8VETTE7
All this great information but not what the Z height is all about??????
Z height is the angle of the lower control arm. It measures the difference between the bottom of the ball joint and the middle of the control arm mounting bolt. It requires a special tool to accurately measure. For just a ballpark height adjustment you can use the measurements in the procedure I quoted and skip the Z height measurement.
The same goes for D height.
Old 06-14-2010, 05:38 PM
lucky131969
Old 06-14-2010, 09:48 PM
socalman
socalman's Avatar
St. Jude Donor '10
I don't know about the fenders being all off that much. I measured 10 different cars, verts and coupes and they were all within 1/8" of these measurements
27.5 Front (ground to fender)
28.75 rear (ground to fender)
Old 06-14-2010, 10:29 PM
flynhi
flynhi's Avatar
Many thanks to all contributors.
W.
Old 06-15-2010, 12:39 AM
flynhi
flynhi's Avatar
Another Q, pls.
What is the typical clearance between top of tire and top of edge of wheel well?
Old 06-15-2010, 08:33 AM
Solofast
Solofast's Avatar
Right, but 1/8 of an inch would easily jack 50 pounds or more of cornerweight, so unless you want to screw up the handling and make the car corner differently turning left and right, do it the right way and measure from the frame points as noted above.
Old 06-15-2010, 08:58 AM
Mark C5
Mark C5's Avatar
Have ten different people measure those same ten cars and see what you get for results
Old 06-15-2010, 03:52 PM
socalman
socalman's Avatar
St. Jude Donor '10
I'm not saying 1/8" right to left, I'm saying car to car. I've had body panels replaced and my fenders are dead on to the frame. If both sides are set same for fenders, the frame measures same (left to right) as well.
What I'm getting at, is for Non racing perfection, if you're trying to see where you are before and after lowering, the fenders aren't as screwed up as people make them out to be.
You might get 9 wrong measurements, but mine would be dead-nuts. I measure daily for a living
Old 06-15-2010, 06:43 PM
JEEP/C5
JEEP/C5's Avatar
This is about what mine averaged before I lowered it some. (I was actually 27/28 on one side and 27.5/28.5 on the other). And that is measured in the center of the wheel from the ground to the middle of the fender lip. (my car is a 2001 z51).
This number will get you close enough for a non-track car.
Old 07-19-2011, 10:56 PM
SG Lou
SG Lou's Avatar
I know I'm resurrecting an old post but i got a question?
That J 6.02 in front and K 6.22 in for the rear measurement, are they
(factory ) referring to having 6 in of clearance between the bottom of the rocker panel and the road ? That seem pretty high no ?
Old 07-20-2011, 08:27 AM
4SFED Z
4SFED Z's Avatar
Yup. 4x4 Status
J/K. I thought it was closer to 5.25ish
My advise, bring it up as high as you need to.
To Stock C5 Ride Height?
Old 07-21-2011, 02:32 AM
SG Lou
SG Lou's Avatar
Originally Posted by NastyZ
Yup. 4x4 Status
Well I did a lowering job on mine and i might have it a wee bit too low.
Here's my thread:
http://forums.corvetteforum.com/c5-t...appy-help.html
Old 07-21-2011, 07:36 AM
AU N EGL
AU N EGL's Avatar
Yup
Measured three cars on a dealers lot and got three different numbers.
Then measured our two and got two more different numbers.
Have also measured two cars and the fenders were the same. but something was not right.
So measured the frame, and the frame to ground was off b 1/8" between the two cars
Old 11-15-2012, 11:33 AM
grumpstar
grumpstar's Avatar
Go to a dealship and measure a new one for reference...
Quick Reply: Stock C5 Ride Height?
