LS2 Stroker
My 402 info is detailed in my signature. I've never had a 383, but the 402 has gobs of torque on the bottom end, I would imagine much more than a 383.
Former Vendor
Difference is that the 402 has a bigger bore 4.00" vs. 3.90" which unshrouds the cylinder valve for more flow which will equal more power, also there will be less piston side load therefore less wear. Down side
more cost need LS2 block,knock and cam sensor extention harness,LS2 front timing cover with cam sensor, and engine valley cover for conversion.
Rob.
Rob.
Rob.
Rob.
St. Jude Donor '12-'13-'14
I like this thread and correct me if Im wrong.
with the 402 LS2 stroker, you can reuse your 90/90 set up, AFR 205 heads ( with a little touch up for your CC), and oil pan. You cant do that with the LS3.
That's a $2000 savings if you go short block build
Id like to do a forged LS2 stroker, but dont know where to turn on it
YES Phil
LS3s well, those take special care and really need a dry sump oiling sysrtem for best results.
Phil Your in Tampa?
Isn't there is a great LS engine builder right there in your area?
Phil Your in Tampa?
Phil Give me a day or two. I need to send a few emails out to race friends that live in the Tampa Sebring area to get the guys name and location.
But my understanding he has been building SBC / LS race motors for years.
Any real high performance use engine should have a dry sump oiling system. We have just seen quite a few LS3s on road course go boom without the dry sump.
Road course / road race engines are run at 3,000 to redline for long periods at a time, 20 min to an hour + . So the need for oiling and cooling is very important.
ARE dry sump is very good. A Daily dry sump is the best
and that will be $5 to my paypal
Tom
Tom
Former Vendor
Adding Dry sump has taken care of oiling issues of the LS3 and LS2s. LS6s can get away with the accu-sump
The bigger the boar the better oiling and cooling the engine needs.
again this is not really for street engines, but high use road race / track day engines that see nothing but 3000 to redline beatings for 20 or more minutes at a time.
Well, that's the pivotal point to your SB decision. AU bases all of his opinions on road racing environment, but for a street/drag car, you get more CI, and more power with a LS3 based block. And yes, you can use your AFR heads either way. I don't believe it's neccessary to go with a dry sump, although they are nice.
