Codes help!!!!!!!!
Codes help!!!!!!!!
In my last post (98 codes) I found out how to pull the codes on it.
Thanks again my the way. My FSM will not be here till next week.
Need to get the car smogged, but can't do it with check eng. light on.
These are thecodes I am getting using the DTC.
10-PCM:
DTC P0410 H C
A0-LDCM:
DTC U1064 H
DTC B2282 H
DTC B2284 H
A1-RDCM:
DTC B2283 H
DTC B2285 H
DTC U1064 H
A6-SCM:
DTC B0851 H
DTC B2606 H
Thanks in advance. glassman74
10-PCM:
DTC P0410 H C
A0-LDCM:
DTC U1064 H
DTC B2282 H
DTC B2284 H
A1-RDCM:
DTC B2283 H
DTC B2285 H
DTC U1064 H
A6-SCM:
DTC B0851 H
DTC B2606 H
The LDCM , RDCM and SCM are totally unrelated to the check engine light so forget those for now. The cause of the CE light is the P0410 HC code.
Do a search on that code and there is a ton of info on what to do to fix the problem.
Here are a couple:
http://forums.corvetteforum.com/c5-t...gas-smell.html
http://forums.corvetteforum.com/c5-t...t-go-away.html
There are many, many more.
Here are a couple:
