Whats the correct answer on balance of LS7 FW when installing a LS7 clutch in a C5Z?
Old 07-09-2010, 12:29 AM
REDZED2
REDZED2's Avatar
Default Whats the correct answer on balance of LS7 FW when installing a LS7 clutch in a C5Z?
Im starting to do my LS7 clutch job just before I install my RPM trans. I have done tons of searching the threads. Just dont know what I should do. My 2003 Z06 factory flywheel has 2 slugs inserted for balance. Now do I remove these and transfer to the LS7 FW in the same spots ?? Or install the LS7 clutch/ FW outta the box and see if I have any vibration. Since I can mark the spot on the new FW where the slugs should go if I need to transfer them to the new FW. Not sure here. Thanks!
Old 07-09-2010, 12:41 AM
Eric D
Support Corvetteforum!
Eric D's Avatar
St. Jude Donor '09-'10-'11
You have the right idea here, except I would go ahead and install the weights in the new flywheel. Chances are they will be needed. If after the new unit is in and if you find you have more vibration than with the old setup, then remove one weight at a time to see if it improves. If it gets worse, reinstall.
Old 07-09-2010, 12:50 AM
REDZED2
REDZED2's Avatar
Hey thanks for your quick reply! What will hold the weights in the new FW holes? Or do they go in very tight? A dab of silicone?
Old 07-09-2010, 01:08 AM
Eric D
Eric D's Avatar
The pins have a raised areas that hold them in place. I balance engines on a regular bases. The pins can be put in and out a few times without any fear of them coming out. If you like, you could put a little of the blue Loctite on them before installing. I would not use silicone.
Old 07-09-2010, 01:20 AM
REDZED2
REDZED2's Avatar
Hi. Actually 1 slug is nice and tight. The other falls right out the other end. I just put a bit of blue loctie around the slug pin, and a bit inside the hole. Should dry secure overnight. Thanks.
Old 07-09-2010, 01:06 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
I had a stock LS6 cutch installed in my '01 and also had a zero balanced aluminum flywheel installed.
Vibrated.
My stock flywheel that was in the dumpster had weights on it from the factory in the form of dowel pins. Normally you would just swap them over but the shop resurfaced the stock fw and put it all together.
Smooth as glass.
I suggest talking to the shop that's going to be doing the install labor, or if it's a garage project, I recommend making friends with your local machine shop staff and ask them. That way you have someone to go back to if you have any issues.
Old 07-09-2010, 01:42 PM
REDZED2
REDZED2's Avatar
Vibrated.
Smooth as glass.
Im doing the clutch and trans swap myself. Dont have time for stuff like that. Either put the pins in or install out of the box. The service manuals seem to say install out of the box. A lot of people have. I have already put the pins in the same location on the new LS7 FW. I dunno everybody has an opinion on this and it I will most likely leave my FW inspection cover off till I know if theres any vibration or not. IT seems this whole thing is hyped a bit too much.
Old 07-09-2010, 01:49 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
^ most cars wont vibrate, but some do...
ALL LS1/6/2/3/7 are fired at the factory and balanced using those dowels if needed.
A machine shop can put the same "imbalance" level into the new flywheel/clutch package. You'll just have to wait a few days with your car apart while they do their stuff.. that's the only way you know it's correct. Otherwise it's a gamble. Do you like dice?
Old 07-09-2010, 01:56 PM
jpandes
jpandes's Avatar
I had an LS7 Clutch and FW recently installed in my 03Z06 and the shop just installed it out of the box. I did get some slight vibration The shop said that they always just slap the new factory clutches in w/o re-balancing. They are a reputable Vette shop in my area too. I spoke with another independant vette mechanic that I have had do some performance installs for me and he also just installs them right from the box.
They're supposed to be Zero balanced from the factory I just have to live with it because I'm not paying another grand for R&R
Old 07-09-2010, 02:29 PM
REDZED2
REDZED2's Avatar
Yes you have a good point there.
Old 07-09-2010, 02:44 PM
lucky131969
lucky131969's Avatar
I disagree. You don't have to "live with it". Any reputable shop should know, that a vibration after a clutch/flywheel swap is unacceptable. They need to fix the issue.
Vibration due to a balance issue can cause damage, and it may be some time before is surfaces...depending on how you drive the car.
Old 07-09-2010, 04:23 PM
Goody
Goody's Avatar
I have my clutch assembly in the trunk of my DD from my '01 Z06 and will be dropping it off at the clutch shop for a balance check. It has two very distinct vibration cycles (underload or not) that I am just sick of having to feel and deal with. I fear it will cause internal bearing damage if allowed to continue. First cycle is 1650-1900 RPM with the second cycle occuring at 3400-3900 RPM. I don't spend enough time at the next cycle point to figure out if it will vibrate there too but assume that it will when in gear.
I had a sticky clutch issue way back when during the extended warranty period of the car (10K). Bitched enough to my service manager to get the clutch assembly replaced under warranty because of the low miles. At that point I thought I started to detect a very very subtle vibration that just wasn't there before. I was told it was normal.
Fast forward another year or so and the engine has to come out of the car (13K). I look at the stock PP and demand it be replaced and once again it is replaced under warranty. Vibration still there and gets a little bit worse (very very subtle).
Car goes out of warranty and I decide to take matters into my own hands and bought yet another clutch kit from a fellow forum member that was/is lightly used. That is the vibration stage I am at now. Can't stand it any longer and have the whole rear sitting on the garage floor as I type this.
I looked at both GM flywheels and one has weights and the other does not. However both flywheels have several lightening holes drilled into them but on opposite sides of the wheel. However, the PP and clutch disk are a Centerforce DF unit and the old is the crappy GM clutch by LUK.
I had considered just buying the LS7 kit but after inspecting the DF clutch it barely shows any wear. So one last attempt at a balancing.
Also, the clutch can be balanced on the car by a shop that has the tool and knowledge to do it using a strobe. But not possible when you have LG headers on.
Old 07-09-2010, 05:34 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Mine had a slight vibration below 2k rpm and would come back stronger at about 5,800 through maybe 6100....
Not anymore though with with original weighted wheel back in place.
Old 07-09-2010, 11:39 PM
REDZED2
REDZED2's Avatar
According to c4c5specialist, the practices they use now, defy and contradict some of the teachings in the GM service manuals. I guess a lot of seasoned master mechanics learn the usual trial and error as you go over the years. I trust his comments and opinions AS factual results and not hearsay. So as about the LS7 FW, the correct practice is to transfer the weight pins to the exact same locations on the LS7 FW. Good enough for me.
To Whats the correct answer on balance of LS7 FW when installing a LS7 clutch in a C5Z?
Quick Reply: Whats the correct answer on balance of LS7 FW when installing a LS7 clutch in a C5Z?
