ATF leak
ATF leak
Hi Guys,
Last decemver I had my C5 serviced and requested the mechanic to change the engine oil and ATF. He followed my instruction but after that the gearbox started leaking.
I have the car since 2007, I am the second owner. Car is driven once a month on a nice day. Car never had problems with the gearbox or was leaking before.
Pics below show current situation. How could this happen and what's your ideas on the solution?
Mike
Mike
i had the same problem. its the gasket that connects the main case to the rear extension housing. its quite common - faulty gasket design. i think the replacement gasket is a different design. the rear needs to be dropped to fix it. i took it to a professional, and he fixed it in a day and a half. it cost me $500, but he had no overhead. it may cost more at a shop.
