'98 M6 trans fluid question
Old 09-17-2010, 06:06 PM
ColeTrain'sC5
ColeTrain'sC5's Avatar
Default '98 M6 trans fluid question
Anybody have the Royal Purple part number for the trans fluid i need specifically for it? Also how about the rear end fluid number? i want to change all my stuff out and can't seem to find it in the Search. Thanks in advance.~Cole~
I know the trans has special seals and can't use the later year trans fluid. Also with the rear gear fluid do i need any additives with the Royal Purple fluid?
Old 09-17-2010, 10:11 PM
ColeTrain'sC5
Nobody knows?
Old 09-17-2010, 11:13 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Have you checked RP's website?
Old 09-18-2010, 12:34 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
You're referring to the paper blockers vs. the carbon blockers used in later transmissions. I'm not sure RP is recommended for your trans...research wisely.
Old 09-18-2010, 11:26 AM
ColeTrain'sC5
Yeah the paper vs. Carbon. I remember reading about them. I also know i've read that the RP will work in mine it's just there are 2 different types for the different trans types.
P.S. Royal Purples website doesn't show anything but where the dealers are.
Old 09-18-2010, 03:06 PM
LoneStarFRC
Click on "Consumer Products" at the top of their home page and then "Automotive" and go from there.
Old 09-18-2010, 11:03 PM
ColeTrain'sC5
I went and got fluid for the rear today and just replaced the trans fluid with the Dexron III that is called for. The hardest part is getting all the fluids in the rear end, at least for me. I got it all in and went into a parking lot and did about 5-6 figure 8's and then drove a few miles and the trans feels like it shifts smooth and the rear sounds extremely quiet and seems to be doing great. I will put more miles on this week and see how it sounds.
Old 09-19-2010, 08:53 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Even though you've already completed this fluid change, for the future, make sure that you never use Mobil 1 trans fluid in a '98 M6 Transmission. Those were made by Birg Warner and have paper blocker rings. Mobil 1, although a great product, will trash those blocker rings and you'll be in for a very expensive trans rebuild. Ask me how I know!
To '98 M6 trans fluid question
Quick Reply: '98 M6 trans fluid question
