Cheap 2 core radiators from Ebay? Your thoughts? Ya im a cheap ass!
Cheap 2 core radiators from Ebay? Your thoughts? Ya im a cheap ***!
Hey guys so im looking at buying a bigger radiator for my C5 only to find out that I need to spend @ $600 +. Anyways im a very frugal and cheap *** so thats not going to swing. So I found this radiator thats big and cheap.
Its not exactly C5 specific, but looks like it would work. What you guys think? It does come with a cap opening, so two caps should not be a problem..........right?
Roger
specs:
This radiator is a universal GM style radiator, and is all TIG welded with no epoxy or rubber seals to go bad, and is fully weldable! 1 1/2" dia. lower right hose, and 1 3/4" upper left. Our 2 rows of 1" tubes out-cool 4 core copper radiators. Cross-flow design for optimal cooling.
* 100% TIG Welded (Great Looking Welds, not cheap messy ones)
* 2 Rows of 1" Tubes
* Fully Weldable
* GM Style Hose Locations (Please check that yours match)
* Cross-flow
* Cools up to 750 Horses!!!
* Plain Aluminum, Fully Polishable!
* Billet Aluminum Filler Neck
Overall Dimensions are about 16" tall X 31" Wide X 2 1/8" core, 2 1/2" total thickness on the headers
So buy it, and install it. You can start a "radiator mod" thread, and take lot's of pics,,,,because others may want to follow in your footsteps...after they see your success.
There is no such thing unless you have money piled up. the Cheapest radiator what will just fall in cost @ $650, this is $180.
I could always make my own brackets to hold it down and buy some aftermarket fans that are a lot stronger than the stock unit
After all the work to make this fit and work, how much are you really going to save, and is it worth it??
Is it worth it? I have no idea, but if it does end up working them yes it will be worth it because of the saving ($400) and it should cool better.
Just saying.
One thing I notice of Corvette member is that they always have a hard time trying to go a different route when something has been set up as the ULTIMATE and ONLY SOLUTIONS to a problem.
Just saying
PS.
I dont mind taking a $200 risk on this one.
Banned Scam/Spammer
Received 1,319 Likes
Oh, I'm sure it's just as good as the expensive ones. Why pay the Corvette tax? So the condenser won't attach anymore, or the fans, or the radiator cover(since now you have an extra pressure cap in the way). And sure, you'll have to do a little cutting here, shaping there....but in the end, you will have succeeded in making a radiator not designed for your car fit and work.
Don't. it's got way too many excuses.
If you really need a bigger radiator without paying retail, I'd advise scouring the classifieds here and on ls1tech for a used one from a built car being parted out. Or, PM guys parting out their built cars that don't specifically mention a radiator, lots of times they might actually have one to trade/$$.
Received 3,812 Likes
St. Jude Donor '03-'04
A stock AC delco Radiator that is a direct bolt in, has hangers for your Condenser and Fan setup cost 265 dollars from any wholesaler. This will insure that your new radiator will work as well as a brand new C5's cooling system..Taking out the old radiator and putting in the new one takes an hour.
I looked at your profile, and unless you have mods that aren't listed there, I don't see why you need a larger radiator. If you don't need it, any money and time spent is just wasted. Put it towards something that will enhance the performance.
If you do have a reason for increasing the cooling capacity,and go with this radiator, just understand that the road less traveled is usually the one with the most potholes.
Well im building a 347 with D1sc. ITs hella hot in South Texas (houston) Summer time is been killing me. With 160 stat in 101 F weather with a/c on I see 240-250 F. It gets hot down here
OK. The supercharger wasn't in your profile. If you have the skills, and the time to do it, go for it. If people didn't try different things we would all be in living in the stone age.
Do document it so others can benefit from your experience.
From the lack of responses regarding the technical aspects of doing this, it looks like you will be the first to try one of this.
im trying to keep that on the down low, but when I post about it makes no difference
