Transmission sealant!!! What to use?
I have my tranny and diff out of my car for a clutch swap. My transmission was leaking where the case is bolted together by the drain plug. I split the case, cleaned up the old gasket and am ready to bolt it back together. What gasket sealant should I use. I have some "Permatex" ultra copper RTV gasket maker. It states that it's sensor safe, good to 700 degreesF and superior oil resistance. Does it sound like this is a suitable sealant or what would you suggest from personal experience. Thanks.
http://www.permatex.com/products/aut...sket_maker.htm
"Permatex" ultra copper RTV gasket maker will work.
Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker or
Permatex® the Right Stuff® Gasket Maker would be a better Choice!
I also have the following:
Loctite superflex red High Temp RTV silicone.
Permatex red hi-temp gasket maker RTV silicone.
Both are good around 600F. Which is a better product for a transmission case? Thanks.
[UOTE=chrisbenoit;1576135851]I also have the following:
Both are good around 600F. Which is a better product for a transmission case? Thanks.[/QUOTE]
Either should work Black would be Better.
(resists auto and shop fluids. First generation 1970-1980 gasket maker.)
Loctite superflex red High Temp RTV silicone. Never used it?
