strange tail light mod. anyone know? pics
this is a c5 that was bought form a insurance auction. none of the rear tail lights work what so ever, and two of them have this strange mod. they drilled a hole in the tail light then wired in some different bulb. anyone know what kind of bulb/mod this is?
http://img830.imageshack.us/i/c5taillights005.jpg/
http://img152.imageshack.us/i/c5taillights007.jpg/
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SOMEWHERE!
You also have a strobe module SOMEWHERE. Dont use them on public streets or highways. That gets police officer attention REALLY QUICK!
BC
BC
anyone have any idea why the rear lights dont work? except the little middle brake light? also back up lights dont work when in reverse, but do flash when i lock the car with the key fob.
any help appreciated
also car was hit on passenger side by the pcm. but from what i can tell wires are ok.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cycle the emergency flasher a dozen or so times and if that doesn't work, the steering column multifunction switch is most likely bad.
BC
The reverse switch on the transmission (passengers side MN6/12) is bad. Very common issue and easy to fix. About $12. as I remember.
BC
BC
yea, found the switch but it was disconected and i dont see where it connects too. not to worried about it, removing them anyway. now, just trying to figure out why i have no brake lights or turn signals or hazards. mabe hazard switch? idk.....
