LS1 Head Upgrade recomendation
Old 12-06-2010, 10:35 PM
bucketlist1957
bucketlist1957's Avatar
Default LS1 Head Upgrade recomendation
I started asking for info about the AFR heads. Not much response. I am looking for people that have upgraded their Heads (any brand) to give a response. I would like to hear your experience and recomendations. I am looking to do a HC in the future.
Old 12-07-2010, 11:48 AM
skyavonee
skyavonee's Avatar
I expect you'll get more than enough results if you do a titles-only search for "afr" or "heads" in the C5 General/Tech/Z06 forums. Good luck.
Old 12-07-2010, 01:33 PM
manley845
manley845's Avatar
What are you looking to achieve? What size cam? What kind of idle quality do you want? Is it a daily driver or street/strip?
A basic 243 head swap would be better than the 241's if you're going with a higher lift cam.
AFR's will be my choice, but they are expensive when compared to other brands. They have high flow numbers while still using smaller runner volumes which translates to better torque AND high horsepower.
Patriot seems to offer a couple choices at resonable prices. If you're looking for higher compression and better flow they have a set with smaller combustion chambers and larger runners.
I haven't researched TrickFlow yet, but have always heard good things about their other heads.
It's too bad the LS1 doesn't have a 4.00" bore, otherwise a set L92 heads would be fantastic.
anywho
Old 12-07-2010, 01:37 PM
lucky131969
lucky131969's Avatar
You could go totally old-school, and call AFR.......
Old 12-07-2010, 01:55 PM
jobberone
jobberone
Support Corvetteforum!
jobberone's Avatar
Call MAST. They are merging with ET. You can get a built set of 227s for $2600 that will flow in the 330 range right out of the box. Throw some YTs on and you've got a reliable fast 7000rpm head.
Old 12-07-2010, 02:01 PM
zeevette
zeevette's Avatar
Get Trickflow heads, and buy them from TEA. More TQ, and HP everywhere on the rev band than the competition. They work with little cams, and big cams, but are a little more expensive. I believe they're worth the extra, and are a great foundation for future mods, 'cause believe me, it's addictive.
Old 12-07-2010, 03:54 PM
manley845
manley845's Avatar
http://www.airflowresearch.com/index.php?cPath=76
Here is a link to AFR's site if you haven't checked it out yet. Look at the links that are on that page and you can read magazine articles, see flow numbers, and even shows a dyno comparison (note the mild 224 cam used that still made over 500hp)
Looking at flow numbers kinda shows the 215cc head to be a good head for something that is still gonna see street use. It has more low lift flow than the 210 and 225cc heads, and almost the same high lift flow as the 225cc head. Looks like a great balance. Gotta think, unless you are just racing, it's the lower torque/power (below about 4,500) that makes the real difference.
I looked at Trickflows site, but if there is good info on there about their products, I could not find it.
Anyways, I am a lil biased towards AFR, but only because I think almost 300cfm with a 210cc head is awesome. That would be horsepower WITH torque. I can only imagine building a motor with thier 245cc heads and seeing the dyno numbers.
I hope someone posts info about Trickflow or MAST, I'm curious about those heads too
Old 12-07-2010, 04:12 PM
99C5JA1
99C5JA1's Avatar
The TFS 215's hit 320CFM at .600 lift (I'm running a milled set). Which is about where most medium sized cams for a 346 are.
I would not recommend swapping 241's to untouched 243's. The small gains just aren't worth the hassle. If you want inexpensive heads, go with factory castings ported by a reputable vendor.
Old 12-07-2010, 11:30 PM
bucketlist1957
Default Experience
I have visited several Manufacturers sites and have a current AFR catalog. I want to know what some of you guys are running that have done HC and how you like what you have. My car is just for play, cruising and a little time at the strip. I would like to get to 450 to 500HP.
Old 12-08-2010, 05:54 AM
099blancoss
Former Vendor
99blancoss's Avatar
St. Jude Donor '10-'11-'12
whats your budget? AFR 205 and a sensible cam is a very good combination. TFS 215 and cam good combination, you can go more money with the MAST black lable heads..
Its all about budget
Old 12-08-2010, 07:22 AM
99 vett babycar
99 vett babycar's Avatar
AFR - talk to Tony Mamo.
Old 12-08-2010, 07:32 AM
ipuig
ipuig's Avatar
St. Jude Donor '09
That would take all the fun out of having pointless conversations.
Old 12-08-2010, 07:33 AM
ipuig
ipuig's Avatar
St. Jude Donor '09
Don't forget to recommend a set of those fabulous MSD wires .
Old 12-08-2010, 08:25 AM
CTD
CTD's Avatar
As others have said, call Tony! I also think the new AFR 210's will be extremely good. I'm going with new AFR 230 V.2 head on a 416.
If you want to explore an alternative as in less dollars, there is thread from a while back in LS1TECH. It was about heads only, stock cam, some very impressive numbers from modified 241/243 heads by AI or Advance Induction.
Old 12-08-2010, 08:56 AM
AU N EGL
AU N EGL's Avatar
Went from a 241 head to a polished 243 head & 224/224 cam
Old 12-08-2010, 09:32 AM
099blancoss
Former Vendor
99blancoss's Avatar
Keep misinforming people your wonderful at it
Old 12-08-2010, 03:19 PM
chevylad
chevylad's Avatar
I have a set of PRC 5.3 stage 2.5 with a texas speed 228R cam and a stock LS6 manifold. I'm happy with the engine setup a six speed and 3.90 gears. It's a nice setup for me which is almost never on the freeway. I don't have a set of AFR heads to compare the subtle things like throttle response of the smaller runner head. The horsepower numbers I saw off different web sites couldn't justify the price tag difference to me. It equated to something like 1000 bucks for an extra 10-15 horsepower. To some this may be a big deal. For me it was ultimately the price tag of the heads that changed my mind.
To LS1 Head Upgrade recomendation
Old 12-08-2010, 03:23 PM
dankhts
dankhts's Avatar
I have friends running both, and next time around I'll probably go for a set of Trickflows, the way I understand it is that they have a different valve angle, and can take quite a bit more cam without fly cutting the pistons.....
currently I'm running a set of done up Lingenfelter 243's with the big valves and high flow porting..... I think they call it stage 2 or 3 or something.....
Old 12-08-2010, 03:30 PM
099blancoss
Former Vendor
99blancoss's Avatar
I have run both on a 347, the same engine with the same cam. Although the peak hp number might have been similar ( the AFR made more by a tiny amount), the avg was not and the car accelerated quicker with AFR's. Thats not to say there was/is anything wrong with the prc 5.3, they are a nice option in their price range. The AFR is twice the money for a reason. Its all in your budget and what you can afford and application.
You could go Patriot, TSP/PRC, Tea, WCCH all on the 5.3's and the price ranges from lowest to highest and achieve similar results. Or you go aftermarket and start with the as cast TFS and go up from there.
AFR 205 or TFS 215, Mast black label are about the best you can do on an LS1.
Old 12-11-2010, 09:41 PM
bucketlist1957
Default Thanks
Thanks for the input from almost everybody!
Quick Reply: LS1 Head Upgrade recomendation
