Battery Drain Issues - DTC Codes
As many have advised to do, I read all of the DTC Codes in manual mode and these are the ones that came up. I have never cleared the codes in the year that I've owned the car. There was only one listed as current:
BCM:
B0433 H: Rear Defogger Relay Circuit
B2528 H: Horn Relay Circuit
B2578 H: Right Front Turn Signal Monitor Circuit
B2583 H: Left Front Turn Signal Monitor Circuit
B2588 H: Column Lock/Unlock Drive A
B2593 H: Column Lock/Unlock Drive B
AO - LDCM:
B2282 H: Battery #1 Circuit
B2284 H: Battery #2 Circuit
U1064 H: Loss of Communications with BCM
A1 - RDCM:
B2283 H: Battery #1 Circuit
B2285 H: Battery #2 Circuit
A6 - SCM:
B0851 H: Battery 1 Out of Range
B2605 H: Seat Front Vert. Position Sensor Failure
BO - RFA:
U1255 H: Serial Data Line Malfunction
C2120 H: TPM System Malfunction
C2121 C: TPM System Programming Malfunction
Any suggestions on what needs repaired to stop my battery from always being drained...??
BCM:
AO - LDCM:
A1 - RDCM:
A6 - SCM:
BO - RFA:
Have you had the battery unhooked in the last year (or near dead battery), sometimes this can cause codes. At this point I would clear them all and monitor for anything which may come back.
I just took it on a few errands and came up with three changes when I got back:
BCM:
B2592 H: Column Lock/Unlock Drive B
99 - HVAC:
B0367 H: Right Actuator Feedback Open
AO - LDCM:
A1 - RDCM:
A6 - SCM:
BO - RFA:
C2120 H & C: TPM System Malfunction
