How to measure a cam?
Old 01-05-2011, 07:11 PM
clif
Support Corvetteforum!
clif's Avatar
St. Jude Donor '09-'10
Default How to measure a cam?
I have a new cam from a supplier that would not give me the specs. I want to measure whatever to determine the specs. Can someone tell me how to measure the cam?
Old 01-05-2011, 07:33 PM
lucky131969
lucky131969's Avatar
Depends how accurate you want to be. You could take some crude measurements with calipers/dial indicator, etc. If you want dead nuts, you'll have to find a shop.
http://www.andrewsproducts.com/Downl...rews_ezcam.pdf
Old 01-05-2011, 10:09 PM
Neil B
Neil B's Avatar
You can measure lobe lift, duration @.050, and installed centerline with a degree wheel and a dial indicator in the lifter bore.
Old 01-06-2011, 05:41 AM
clif
clif's Avatar
Thanks. I have a friend that owns a machine shop. They said they will measure it for me. They do not usually do engines, but, they have more multi-axis CNC machines than most, and CMM (Coordinate Measuring Machine) that they say can do it. I will let yall know what it turns out to be!
Old 01-06-2011, 07:46 AM
AU N EGL
AU N EGL's Avatar
What is / are the numbers on the end of the cam ?
Then go to the manufactures web site and look it up. There are really only 2 or 3 cam manufactures so not that hard to look up.
You should be able to get close.
Old 01-06-2011, 11:01 AM
clif
clif's Avatar
It is a new Comp Cam that was custom ground for a vendor; so they will not disclose the specs.
Old 01-06-2011, 11:07 AM
clif
clif's Avatar
Here is a picture of its end:
Old 01-06-2011, 12:01 PM
Neil B
Neil B's Avatar
Here's my guess:
CC = Comp Cams
HR117+5 = Hydraulic Roller 117 Lobe Separation with 5 degrees advance
13019R/13023R = these are probably the lobe numbers, call Comp and they can tell you the duration and lift of these lobes.
Old 01-06-2011, 12:12 PM
lucky131969
Here's my guess:
CC = Comp Cams
Old 01-06-2011, 12:34 PM
clif
clif's Avatar
Thank you all!
Old 01-06-2011, 12:39 PM
0Jon@Texas-Speed
Former Vendor
Jon@Texas-Speed's Avatar
235/251, .620/.623, 117 lsa, 112 icl
Old 01-06-2011, 12:58 PM
clif
clif's Avatar
Wow, How did you determine this so fast?
Do you think this will be a good blower cam?
Old 01-06-2011, 01:01 PM
lucky131969
Jon,
Are those numbers for LSL lobes? Just wondering.....
Comp Cams LSL Lobes
13014R 265 215 139 .355” .604”
13015R 269 219 143 .357” .607”
13016R 273 223 147 .359” .610”
13017R 277 227 151 .361” .614”
13018R 281 231 154 .363” .617”
13019R 285 235 158 .365” .621”
13020R 289 239 162 .367” .624”
13021R 293 243 166 .367” .624”
13022R 297 247 169 .367” .624”
13023R 301 251 173 .367” .624”
13024R 305 255 176 .367” .624”
13025R 309 259 180 .367” .624”
13026R 313 263 183 .367” .624”
13027R 317 267 187 .367” .624”
13028R 321 271 190 .367” .624”
13029R 325 275 193 .367” .624”
Old 01-06-2011, 01:27 PM
Neil B
Neil B's Avatar
IMO, it seems like a great blower cam for a 400+ inch motor.
Old 01-06-2011, 01:28 PM
clif
clif's Avatar
Thanks, my motor will be a 454 cubic inch LSX motor, with a 9.0 compression ratio.
Old 01-06-2011, 01:42 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
An engine machine shop can get the EXACT cam specs off ANY cam with a tool called a "Cam Doctor" call around and find out who has one----
Old 01-06-2011, 01:44 PM
Neil B
Neil B's Avatar
454ci will swallow up that cam no problem. It'll probably idle very smoothly especially with the wide lobe separation.
To How to measure a cam?
Quick Reply: How to measure a cam?
