Reprogram Key Fob
First try to resync the fob to the car by holding down the lock and unlock buttons at the same time on the fob until the horn honks. If this works, you're all set. If not, then follow the relearn procedure in the manual. You really shouldn't have to relearn when you change the battery.
St. Jude Donor '13-'14-'15
