DIY Minitub??
DIY Minitub??
Anyone have the pics for the diy minitub? the pics are gone from this link
https://www.corvetteforum.com/techti...=240&TopicID=1
CF Veteran
St. Jude Donor '10-'12
CF Veteran
Here are the pics that go with this write-up.
Step 7:
Step 8:
Step 18:
Step 23:
Step 38:
Step 7:
Step 8:
Step 18:
Step 23:
Step 38:
Wow! Is that really all there is to it? No structural changes or metal moved at all??? Just cut the wheel house and widen it?
That's awesome, definitely a future project for me..
It usually allows you to run a 30 inch or so plus tall tire and they're as wide as I'm sure you've seen on show cars.
Basically a mini tub doesn't USUALLY allow wider than 345MM tire and allows you to keep your trunk/backseat fairly stock and usable.
A full tub will not allow either.
ET streets or something similar like the Nitto's above will hook ALOT better but 600+ with IRS in a C5 and you'd be spinning 2nd no problem if you go WOT at any point in the RPM band roll or stop.
3rd you may have to rev it a little and drop the clutch but you'll spin if you want to
I posted this message in the general thread but if I could get some of you fine gents to comment on it, I'd be grateful. The more the merrier.. Thanks. (and yes I know this is a really old thread). New post is here:
https://www.corvetteforum.com/forums...post1590847153
