Adding high-flow cats to my longtubes, to pass VA emissions?
Hey everyone,
My 2000 corvette is vortech supercharged and has Texas Speed longtube headers, with O2 simulators. It also has a custom tune for this setup. If I want to add highflow cats to the exhaust system, is it correct to assume that I will have to get the car retuned? Also, will I have to buy new O2 sensors or wiring, since the car currently has 02 simulators? I need the car to pass emissions in Virginia! If you have any suggestions on types of high flow cats or anything else, please let me know!
Sincerely,
Jason M.
Sincerely,
Jason M.
If they test by plugging into your ECM you should be OK because the simulators fool the computer.....sniff test maybe not....click link below for some info..
http://www.deq.virginia.gov/mobile/mobfaq.html
If they do a visual - you'll want to have cats. Other than that, just make sure it's not throwing codes and you'll be fine. 02 sims are themselves illegal and shops stopped selling them a few years ago to avoid Federal prosecution. It's just much easier to tune them out.
The inspector asked me if there were any codes. I replied "None that you'll ever see."
My car passes every two years.
Just as an example:
http://www.jegs.com/i/Magnaflow/642/...0002/-1?CT=999
Not knowing whether you have an aftermarket X-pipe or what size it is - hard to be more definitive than that.
Call Robert's Custom Exhaust in Stafford - the very best in the area.
http://www.robertscustomexhaust.com/
Just as an example:
Thanks again!
Since the cats will only cost you 2-3rwhp, I seriously doubt you'll need a retune.
If your car is tuned, and you aren't throwing a check engine light, you are fine. I passed with leaded gas in the tank. Haha.
If they do a tail pipe test (they shouldn't), you are screwed
I don't have any check engine lights, but if I use the onboard diagnostic system there is one current code and a few history codes. But these don't cause the check-engine-light to show up, so I should be fine?
