Proper way to measure when lower C5?
Proper way to measure when lowering C5 Z06?
Hey:
Everyone seems to measure off the Z06 fenders and I think that is very inaccurate. Someone mentioned measuring from the factory jacking points on the body. So what do you think?
Also, whatever body part you suggest measuring off of, tell me how low you can go (measurement) before you mess up the suspension/handling of the car. It is a Z06
Also, a lot of guys suggest using a 6" bolt, does anyone have a part number?
Thanks.
-Kyle
Thanks.
-Kyle
The proper way would be using scales.
If you put a 6" bolt in the rear then you will have your car sitting on the bump stops. The car is on the bump stops in the rear when the rear tires are about 1/4" up inside the wheel well. The front has some more travel but not much.
You can lower about 3/4" before you're going to far and beginning to mess up the handling. The car will also start to ride crappy as you go lower due to it hitting the bump stops hard.
Peter
Peter
I asked the same question a few days ago as I was trying to dial in my new coil overs....I was directed to the service manual which says that ride height should be measured to the lower bolt on the A-arms. I was able to do that by getting down on my stomach. I used a little adjustable gage you can get at the hardware store and then measured it using a ruler....a little more accurate than trying to get a tape measure under the car. Also make sure you're on a level surface.
Here it is
The search feature is your friend. Here is a link to a thread that describes the measurements to the J and K dimensions (the frame at the jacking points) that you can use.
http://forums.corvetteforum.com/c5-t...de-height.html
These were in the 2001 manual. They aren't in the present manual, in that manual they have you using the GM tool and measuring from the ball joints to the frame. That method is accurate no matter what tires you are using. If you have tires that aren't the OE sizes that can change things.
That's how I did it....
From the other post I got these numbers below but are they for a Z06?
Trim Height Specifications
Base, FE1, FE3, FE4-----------J Height (Curb)-----------K Height (Curb)
Service Preferred--------------153 mm (6.02 in)---------158 mm (6.22 in)
Service Allowable--------------153 mm (6.02 in)---------158 mm (6.22 in)
Also, the manual does not say how low you can be from these measurements. So if I go an inch lower, that would put the car at 5.02 front and 5.22 back? Would that be correct?
I want to hear more peoples opinion on this as far as how low you can take this car before it messes your handling up? I want to lower my 02 Z06 but not past the point where it makes the car handle bad and messes with the suspension.
Thanks.
-Kyle
Thanks.
-Kyle
Thanks.
-Kyle
Thanks.
-Kyle
Having said that, I dropped my '01 coupe about an inch, back when it was brand new, based on what I could get by going as far as I could on the front spring bolts, then dropping the rear an equal amount, and also keeping the built in "rake".
I can only offer opinions in regards to having coilovers...
When I got my coilovers installed last year, I let the experts handle the settings. After installation, they set the "ride height" by approximating about how high the car should be for normal driiving but also for competitive driving (it was a racing shop that actually builds and races corvettes in various performance classes). I told them I didn't want it completely slammed, but definitely lower. After approximating the ride height, they basically started over by corner weighting and balancing the car using scales (raising and lowering each corner as needed to achieve a near 50/50 balance side to side and front to back). As a result, my front wheel well gap to the tire is actually more than the back. And my driver side rear wheel gap is slightly smaller than my passenger side rear gap. It's really about balance for me...not looks. (Although, I think it looks killer!) The result is a *very* balanced car that can stay flat through corners no matter how stiff or soft I set the coilovers. It cost me extra to do the balancing, but man, was it worth it!
Notice the rear gap is less than the front:
