Alternator replacement DIY??
After pulling fuses and checking everything that I could think of I was at wits end. Turns out that the alternator (looks to be the original) is not working properly so I need to replace it. Looks to be fairly straight forward process but I'm wondering if there's a DIY that can be of some help? Any help would be appreciated.
the tensioner for the upper drive belt is on the opposite side of the engine bay from the alternator close to the battery compartment. Put a wrench on that and release the tension off the belt so you can remove it. Good luck
As I've only had the Vette since last November I wasn't sure if there was anything "different" about it. Like I said in my original post it looks fairly straight forward but it just looked "too easy". I guess I'm more used to the overly tight engine bays of my past vehicles.
Very easy... its just as easy as it looks.. Be sure to have a Belt routing diagram, that can be the funny part that makes it take more then 10 min. as for the bolts, snug them down, they dont need much snugging to be tight.
Be sure to get a quality alternator, AC Delco/Delphi are my top choices. Rockauto.com is usally reasonable and you can find 5% off cupon codes if you google it.
Belt routing:
Belt routing:
Went with a reman'ed AC Delco 110A alternator that I found locally. Rock Auto had the 150A but I didn't want to wait and have to deal with core charges/returns.
It was down right one of the easiest removal/install process.
Be sure you get the right one for your car. As I recall, the early C5's (97-01 according to RockAuto) had a Valeo unit with a bunch of "special" circuitry.
Also, what exactly makes you think your alternator is bad? Did you pull your codes? Are you seeing a "Charge System Fault" message on your DIC?
I first saw the "Charge System Fault" error message a few months ago, after which, it appeared more often. I started out a few weeks ago with checking out and replacing the battery outright but the error message still persisted. The voltage when the car was running was rather erratic, anywhere from 11 to 14.5 volts.
that's bad news. when functioning correctly i have never seen voltage under 13.0v and the alternator self regulates between that and 14.4 or 14.5v
may see what it costs to have yours rebuilt versus the $200-250 of a delco 150a replacement
I would opt for that since you have one of the Valeo units. I believe that is what Bill Curlee (you might even ping him) recommends. You cannot put an 02+ type alternator in your car.
Already pulled the trigger and installed the AC Delco 110Amp unit yesterday. No faults or error message so far. If things go south again, I may bite the bullet and go for the Billet Tech one.
