Catless and smell
Catless and smell
So I was going to pass on headers for a while, but I found the OBX headers...
http://cgi.ebay.com/ebaymotors/OBX-E...item2c5cc663ff
I don't want to get into a debate about the quality or price! I really just want to know if these are going to stink up the cabin...I am running the stock cam. They appear to be the bolted/donut type connection from the header primary to the x-pipe, so the seal looks like it should be good. My old pacesetters stunk because it was a crappy slip fit connection.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Contact SUPERMAN 09 and talk to him about XS Power headers. They work excellent and have an excellent ball and socket fit:
I had them on my 06 and installed them on a friends 04 Vert. The ball and socket collector fit works fantastic!
Why do you want to go catless???? You only gain 4-5 Hp and the smell will be more than you want to deal with. trust me.!
BC
BC
well, you gain more than 4-5, but yea the smell is VERY noticeable on catless cars. if you've never driven a muscle car, its barely any better than that. unless you're doing real racing or if this is not your daily driver, its not worth it imho.
St. Jude Donor '08
I was very worried about the catless smell. I bought my headers used and the cats had been gutted so I just installed what I got. I had my pcm bench tuned by ECS. Suprisingly, the smell is almost the same as with the factory cats. at start up, you can smell the gas but you can smell the gas when I start my truck and wife's equinox too. after a few minutes, the smell is fine. I have only had the targa off once but I could not smell the exhaust in stop and go traffic. I read a bunch of threads on here before I went catless and I saw mixed replies. some guys said the smell was horrible, some said it was fine. A few guys said that with a good tune, there should be no smell so I've credited ECS with the lack of a bad smell from my car.
I will monitor the smell all summer and may add cats over the winter if I find the smell is bad.
I won't even touch the enviromental side...sorry mother nature.
you guys are making me wonder how rich im running seriously? NO SMELL? i mean, you guys can smell your wive's cooking still right? when you start the car in the morning there's NO SMELL?
to be fair, my c3 454 with sidepipes doesnt smell like fuel either. if you exhaust is smelling like fuel, the it needs to be tuned.
ok, it smells no different than it did with the stock exhaust. before it was tuned it was rich and you could smell the fuel but after tuning it just smelled like a normal exhaust.
St. Jude Donor '08
to clarify, when I start it cold, it smells. but as I mentioned above, it is no worse than any other vehicle I own. and after a couple of minutes, the smell goes away.
I blew out my hi-flow cats and had to gut them out. Absolutely no
difference I can smell and I daily drive the car. Even my wife can
not tell the difference.
Wayne
Wayne
Installed HF cats to a previously catless system; no difference in stink; modest reduction in noise. Much more difference when switching from a cam with +8 deg. overlap, to a cam that's -2 deg.
before i got mine tuned in the garage idling it would make my eyes burn like a poorly tuned carb but after tuning it was not a problem. even my wife noticed the difference.
Had kooks 1 7/8" with a 3 inch catted kooks pipe and z Ti catback. Recently switched to a non catted kooks pipe and can barely tell a difference. Inside the car...i cant even smell exhaust. Outside...there may be a slight difference but not much.
