2004 fuel pressure
2004 fuel pressure
Can anyone give me what the fuel pressure is from a stock LS1 2004 fuel pump? I've researched the web with no answer. I'm using the 04 tanks and stock pump on a LS3 that requires 60psi. Before I upgrade to a new pump I was just curious what the pressure is of the one I have. Not hooked up and running yet so I have no idea what I have. Thanks.
04 Fuel Pressure
What I need is a constant 400 kPa with the engine running with a minimum 40 gph @ 400 kPa. I was not sure if the stock pump will deliver that. If I install the tanks to test the pressure and it isn't what I need I have to remove the tanks to install a new pump. Just wanted info on CONSTANT pressure if that info is possible. Not sure if 58# is what I have. If it is, it's not enought.
Or Aeromotive now offers their new "Stealth" 340 lph drop-in fuel pump module for late C5s and C6s as well. I'm sure it will give you all the volume you need, and probably pressure as well. If not, there's Kenne Bell Boost-A-Pumps too like 8VETTE7 said and it only kicks in at WOT.
400 kpa = 58psi. (414kpa = 60psi)
40 gph = 151 lph.
Stock GM pumps are generally 170lph or 190lph for "higher powered" stock vehicles. Also, vettes are "4 bar" fuel systems -- which means they maintain around 58psi at idle (e.g. the FPR is set to 4 bar / 58psi). The vettes are 190lph, I believe, and as stated above, ring in 55 - 62 psi. Injector flow rate may drop (or increase) your rail pressure, e.g. you may change injectors and see your FPR drop from 58psi to 57psi, but its still a 4 bar fuel system running at 4 bar.
Even if you buy a replacement pump for a vette, unless it has an adjustable FPR, it limit pressure to 4 bars. You only need to increase your fuel pressure to "increase" the size of your injectors (e.g. I run 135 gph (510lph) at 400kpa (58psi) to stretch my injectors to 116 lb/hr from 96lb/hr (as rated at 43.5psi/3.5 bars), but I could also buy 116lb/hr injectors rated @43.5psi and turn down my FPR to 43.5psi and would have the same results -- I wouldn't even have to change my tune).
In any case, the stock pump and FPR both exceed or match the specifications you stated.
Or you could buy a new fuel pump and find out that's not the problem.
