C1225 LF Excessive Wheel Speed Variation
so this is the current code my 99' has. Traction control comes on when i hit about 60 mph and kills power slowing the car down. But the dash has NO lights such as abs traction control. when i hit a bump hard on the free way the abs and traction control come ON.
I used to have C1232 LF Wheel Speed Circuit Open or Shorted but i swapped the wheel harnesses from right front to left front with each other. this got rid of C1232 code. i no longer have that code. but now i have C1225.
what could be the problem. the only other code that comes up is tire pressure monitors that i currently are not in the wheels.
i have stock z06 rims 17 in front 18 in back.
please help!
please help!
Check the harness wires with a meter for resistance. If you can back pin (using a small probe with your meter to touch the wire inside the connector)the connectors while plugged in, you can see how good the connectors are also.
