No Left or Right Turn Signals
Yesterday my left and right turn signals both stopped working. The DRL's and stop lamps are all working, and the 4-way flashers are also working.
Could the multifunction switch be the cause?
St. Jude Donor '15-'16-'17-'18
You Hazard switch is bad. I believe they are around $30 at GMPartsHouse.com.
The relay for the signals is built in the switch, however you 4 ways will continue to work.
There's a write up floating around that shows how to swap the switch without removing the dash cover.
Thanks CamminC5, I need to fix this ASAP.
I get a decent discount on parts from a Chevy dealer in MA, just north of where I live.
Let's hope they have the switch in stock.
The Hazard Warning switch had to be ordered, and I won't have it 'till next Tuesday.
I "exercised" my Hazard switch on and off several times, and now the turn signals are working again........hope this lasts through the long weekend.
Thanks again.
Thanks again.
Mine was failing for like a year. I would just hit the switch 20-30 times and it would work for a few weeks, then i'd do it again. Its annoying, but it should get you by until you can install the new part.
I recently purchased a C5 and started having issues with my flashers intermittently working. After doing research here on the forums, I opted to buy a flasher fix relay at www.corvette-enhancements.com You can buy the relay fix through a couple online retailers. The stock switch will eventually go out again due to the design. The flasher fix was a simple install which took me all of 10 minutes to do. It's been working great since.
I just never pressed the hazard button ever again.
Since I already paid for the hazard switch when the dealer ordered it last week, I'll pick it up today just to have one if I ever need it.
