Wilwood caliper direct replacement for OEM caliper
I did a search but could not find a answer to this question.
Like the title says. Does Wilwood make a 6 piston caliper that can simply be changed out for the OEM caliper on OEM wheels ( commemorative Z06 wheels).
For those who have seen the Wilwood BBKs. They know that the kits cost several thousand dollars, just for one end. My search and reading indicates that the stock rotors would be just frine for street applications. But the 6 piston caliper (4 on the back) would result in improved braking. The full BBKs are cost prohibitive. But the calipers themselves are much more affordable. I already have Hawk pads, Motul 600 fluid, and SS brake lines. In reality all I am missing are the Wilwood calipers.
So does anyone know if Wilwood makes a direct replacement caliper?
No they do not. The Wilwood's are a radial mount that requires a different bracket design. Look at the LG Motorsports G Stop kit. It uses a SL6 6 piston caliper, stock size rotors and will fit under stock size C5 Zo6 wheels. Great bang for the buck !
After I posted this I did another search. I found several references to the mentioned LG Motorsports Brake kit. But I went to their site and couldn't find it. I not sure if the kit is still available.
...My search and reading indicates that the stock rotors would be just frine for street applications. But the 6 piston caliper (4 on the back) would result in improved braking. The full BBKs are cost prohibitive. But the calipers themselves are much more affordable. I already have Hawk pads, Motul 600 fluid, and SS brake lines. In reality all I am missing are the Wilwood calipers...
- Its a common misconception that increasing the number of pistons (saying from 2 > 6) improves braking. The OEM slide rail calipers have the capability to stop the car every bit as well as a $5K set of Brembos (within a few feet, given same tires, pads...etc). On the street that is, where common usage doesn't involve repeated braking from 140-60MPH every 2 minutes. Other than the bling factor, the main reason to upgrade to BBK brake systems is for track use where heat management and preventing brake fade are critical.
- Not sure how to read your statement on hawk pads and ss lines. If you are thinking that the pads you currently have will fit in any of the BBK calipers then, unfortunately they will not. Pretty much each caliper takes its own specific size of pad. Now, having said that, the pads for the Wilwood SL6 are very common and cheap, compared to the pads for the OEMs. Also, its unlikely your current SS lines will fit different calipers.
- Motul 600 is excellent on the track but gains you nothing on the street (unless you are doing serious canyon carving with heavy, repeated braking)
- Not sure what rims you currently have - there are very few aftermarket brake kits that will fit under the stock front rims. That LG SL6 kit will fit under the C5 Z06 17" fronts, but I don't think they will fit under the 17" Y2K rims for example (without spacers). The AP racing CP8350 calipers will fit under the Z06 fronts also. Other than that...I'm not aware of any.
- If you have 18" fronts with lots of rotor to spoke clearance then there are many more options.
Here ya go -- http://lgmotorsports.com/GStop-6-Piston-Brake-Package
Having read the description it appears to be a front wheel conversion and does not include the rear? It would just seem logical that if you upgrade the front shouldn't you upgrade the rears? To keep the car balanced?
Then there is the more superficial question. My calipers are currently red powder coated. Does anyone know if the LG motorsports would supply the calipers in red?
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
If anyone has any questions about the kit, I'm happy to help.
Are there any comments on the second paragraph of my last post?
Received 8,924 Likes
No you do not need to upgrade the rear calipers. I ran the G Stop kit for 4 years on my C5Z. It solved the problems I was having with the stock caliper which was pad taper along the length of the pads which would then cause a long pedal. After 4 or 5 track sessions the brake pedal would go so low it was below the level of the gas pedal and I couldn't heel toe anymore. The pads are really thick with the G stop kit and they last a long time and also happen to be lower cost than the alternatives. I used Wilwood H on the track, Q on the street and E for autocrossing. There were matching pads for the rear. Overall a low cost, effective solution to the C5 brakes. I used NAPA Rotors and could get 3 to 4 track days out of them before they cracked which is the same as I was getting using PF 01 pads in the stock calipers.
Once I installed this kit I had confidence in my brakes. I could go into corner after corner and know I was going to have brakes without double tapping the brake pedal with my left foot while running down the straight. That allowed me to run harder and reduce my lap times.
Bill
Bill
Former Vendor
John Shields an a few other guys have the rears on their cars.
