Radiator Drain Plug Question
Recently changed coolant & hoses. Drove a few hundred miles since, but just noticed some coolant on garage floor. It's coming from drain plug, which seems to be seated properly (I got my 1/8" drive & turned in counter clockwise a bit then clockwise to be sure its in).
Got a new plug on hand. How do you get the old one out WITHOUT BREAKING ANYTHING??
The OEM drain plug is a fragile POS. It is real easy to break the pin off. Turn it 90 CCW (ONLY 90 degrees) and pull straight out with pliers. Then check to see if it has a pin on ONE side and an o-ring still on. If all that is good, then replace with new plug. If any of that is missing you will have to figure out if it is jammed up in the drain hole. I used an inspection camera when I had the same problem--good luck.
Thanks for the help guys!
Since I only put 3k miles annually on my Vette...& change coolant every 3-4 yrs....I doubt it's corrosion. Probably the o-ring as you suggested.
I just hate to waste 2 gallons of new Dex-Cool. But I guess there's no way to save it if changing the drain plug.
If you want to make sure that you have filtered the DexCool properly, put a coffee filter paper in the funnel. It will be a little slower to fill, but it will definitely get the garbage out.
Painters use disposable paper funnels with a screen mesh built in for when they pour from the can into their paint guns. Much better. Cheap too.
Coolant can look fine but still be corrosive, with no anticorrosion additive left. The only way to be sure is to use a coolant test kit for long life coolant.
These kits will allow you to check PH, anticorrosion additive level and freeze protection.
Coolant slowly becomes corrosive because minute amounts of carbon dioxide from the combustion process gets into the coolant, molecule by molecule, past the head gasket, forming carbonic acid. Once the anticorrosion additive is gone, the coolant will eat something else, like headgasket steel and aluminum parts.
Another option to using a test kit is to change coolant frequently, every three years for long life and every two for standard green appearing coolant. These intervals are conservative, of course, but you usually are unable to get all of the coolant out on a change without removing the waterpump.
If you DRAIN IT IN A PAN you won't LOOSE IT
It's NOT MILK, won't spoil when it hits the air.
Have done this several times when I had to replace a defective water pump multiple times in a few months. Its not going to be ruined by draining and replacing with a funnel.
Well, after draining coolant into a clean jug....
replacing drain plug....
refilling cooling system....
bleeding system....
going on a test drive....
guess what?
next day there was more coolant on garage floor...again!
So this time I looked from top down.
turns out one of the small coolant hoses on right side was leaking....
& making it's way down to bottom shelf...
right under drain plug!
Took off air intake assembly & related parts in order to get to the only hose which is NOT accessible (of course) & snugged up worm gear clamp.
PROBLEM SOLVED!
bleeding system....
guess what?
PROBLEM SOLVED!
