Wierd LED Problem Experts Needed
Old 08-22-2011, 09:30 PM
98ta bandit
98ta bandit's Avatar
Default Wierd LED Problem Experts Needed
Car is a 01 C5 coupe M6 Led-Rearview Mirror. Everything has worked perfect until I ordered LEDs which includes the bulbs for the trunk lights and LED strips for the footwell lights all Led bulbs are plug and play, they all light perfect. I have a Escort Radar Detector that plugs into the rearview mirror with a quick connect pigtail that slides into the mirrors power outlet, which means if I have the doors closed and the car running the radar detector will power on. Here is the problem-with everything pluged in all the LED lights including the mirror lights will stay lit up if the car is running, if I unplug the radar detector everything works perfect. It seems to me like the radar detector is backfeeding the LEDS-which the Radar is getting its power off the mirror itself from the quick connect pigtail. Im wondering if its a wiring problem. Do you know of any solution that would allow me to keep my LEDs and Radar Detector quick connect? Or should I just give up on it and run the radar detector off the radio ignition wire and just leave the mirror alone?
Old 10-03-2012, 09:19 PM
WHITEVERT04
WHITEVERT04's Avatar
I have had the same exact problems. Did you ever get it fixed? Looking for a solution to the same problem. Thanks
Old 10-06-2012, 07:21 AM
JropTop
JropTop's Avatar
From what I recall,there are 2 power feeds on the back of the rearview mirror,use a test light to see which one is switched,I cant remember off hand which 2 colors I used.
Old 10-06-2012, 12:51 PM
FRITZM
Support Corvetteforum!
FRITZM's Avatar
Default LEDs
I think, from what i have read on the forum, that there are three wires in a taped bundle near the passenger side floorboard fuse box. One is yellow, one is orange and one is black. I think either the yellow or orange is switched. Should be easy enough to figure out. Black is ground. You could route your quick connect wiring under the carpeting. Just a thought. A fuse in the line might be a good idea also.
To Wierd LED Problem Experts Needed
Quick Reply: Wierd LED Problem Experts Needed
