milling heads question to gain compression
i have an 01 z06 stock 346 cube, and i have 66cc PRC heads on it and a .615/.612 cam in it. when i was checking ptv clearance i had plenty of room. i put on some gm mls head gaskets hoping to get close to my factory compression ratio. i was thinking bout milling heads so i can get some more compression out of it. id like to get 11.5:1 or around there. should i mill to maybe a 62cc head? not sure on how much need milled and how low of cc i should go in the combustion chamber. any input would be appreciated!
using wallace racing calculator, it says to go from 10.5-11.5:1 is to mill heads .030 . seems like a lot. but i dont know how much that would knock my cc's down to..
