Squeaky steering wheel
Old 09-28-2011, 07:43 AM
Bluemill
Bluemill's Avatar
Default Squeaky steering wheel
This is not a biggy, but it's worth asking about. I have a squeak coming from the steering column, sounds like a foot outside the firewall. You hear it in parking lots, driveways, doing parking maneuvers. I know it needs lubrication, but how do you get there without destroying your car?
It's very tight in that neighborhood.....
Any suggestions would be appreciated.
Best,
Bluemill
Old 09-29-2011, 10:15 PM
TEXHAWK0
TEXHAWK0's Avatar
IF it sounds like it is under the hood, try the bearing in this article.
https://www.corvetteforum.com/techti...D=35&TopicID=1
Old 10-03-2011, 04:48 PM
Bluemill
Bluemill's Avatar
Default Where is this located?
I have lithium grease that I can inject, but where is this bearing, and can I reach it without taking the column out of the car? I could take out the the windsheild washer fluid reservoir, and that's pretty easy, but other than that, things looks are pretty tight in there- and complicated to extract. I do not think that removing the master cylinder would be advised - but maybe I can get the booster out of the way, without monkeying with the brake lines.
The picture in the link you sent looks like it's out of the car- and I have no idea which end it's at.
The noise is definitely under the hood.
Help!!
Thanks for your response..... it's the only one I got.
Best,
Bluemill
To Squeaky steering wheel
Quick Reply: Squeaky steering wheel
