Low Oil Level and ??????
7th Gear
Im getting the "low oil level" message in my 02 Z. Here is what has happened (This entire time the actual oil level has been perfect, and car has been on an almost level surface):
Driving onto the hwy and I lose power for 1/2 second.
Two days later Im 1/5mi down the street after starting it and it just shuts off while driving. Try starting 10 times but the engine just shuts off after a second each time. Finally starts 20mins later and I get it back to the house. Now, once I start it to put it in the garage I get my FIRST "low oil level" message. Jack it up and find some melted wires (near the headers) that look like they may be bad... replace and starts fine. Im driving it easy for 20mins and my engine shuts off as Im coming to a turn... I coast into a gas station. I add 1qt oil just for the hell of it. No help, still getting error message and engine wont stay on for more than a second. Get it towed to the house and find the oil level sensor wires may be melted bad too (thanks headers!). Im disconnecting the harness from the sensor and I find someone had already crimped one of the two wires for repair... it broke off when I pulled slightly. Fine, it should be the wires then right (called Chevy and ordered new harness). I have them DISCONNECTED from the oil level sensor now and go to move it in the garage.
Here is whats weird...
Battery is dead so I charge it fully. Go to start it to move into the garage. Start it, pop the clutch to move it a whole 4ft before the engine shuts off again. BUT the second time I start it, its running perfect and stays on (oil level sensor is unplugged). Now, wouldnt the engine shut off again like it has been? At this time I have NO error message! I start it 2hrs later just to test it again... runs perfect again but now I have the "low oil level" error again.
Does the computer on C5s freak out if it has a low battery? Some of this just doesnt make any sense
Please help!
Please help!
Please help!
Please help!
Pull your codes: http://www.c5forum.com/ayc/dtcdic.php
Also, if the wiring is damaged from heat, then everything needs to be inspected.....especially the O2 harness and crank sensor wiring.
Yup... low batteries cause all kinds of weird issues on this car. Replace those melted wires and you should be good to go. Make sure they are away from the headers. Also, check your oil level. Since you stated you added a quart without checking the level you might be a quart too full now...
7th Gear
Thanks... Yea I figured the engine was shutting off automatically because it thought it had no/low oil (precaution). It's just weird that once I mess with the oil level sensor, the engine runs fine even though you say it has nothing to do with it. I don't doubt you, I'm just trying to understand this!
I have a professional tester and the only code it is throwing is P0803 (1-4 upshift). This has been on for a while even though I have reset it. The car has run perfectly fine. Any quick advise on that would be great!
Seems like I just need to inspect all my wiring and wrap those around the headers.
7th Gear
Alright I pulled all the codes per the link as well... NOTHING comes up.
Replaced the oil level sensor and the harness. All other wiring is fine.
Car still shows "low oil level". I had the car running for 5mins (all gages showed normal), pulled it out on the street, and the damn thing shut off again 3 houses down.
I have no idea what it could be now.
Please help!
Please help!
7th Gear
I cycled through all the codes. My car only has 22,000 miles on it so I dont think its that hard to believe. And no, I dont track it.
I disconnected the battery for a day and the low oil level warning was gone. Now its back a day later.
I dont really have a way to check possible fuel related issues... filter, pump, etc. I think it might be one of these though.
Unless someone has some experience with this, I think my car just needs to go to Chevy because its driving me crazy (no pun intended!)
Then you own the only C5 ever made that can run with melted wiring harnesses from Bubba's header install and repeatedly stall without throwing any codes. Everyone else's C5 throws codes when they sneeze BUT NO NOT YOURS.
7th Gear
Unless you have some useful information, which is why this forum is here, run along. Thanks for your copious input!
So there are 2 possibilities here.
1. You have an incredibly unusual stalling C5 with melted wiring that doesn't have any trouble codes
OR
2. You did not (correctly?) inspect said codes
Now if we two were to switch sides of this debate, honestly tell me which of those would seem WAY more plausible to you? You know I'm not the only incredulous poster here, right?
7th Gear
I understand your skepticism. I too have noticed that most people cant do the simplest tasks, but I assure you I can press a couple buttons to start the scan and then press options to cycle through each module.
The following reads for each module: NO CODES
I must have an incredibly unusual Corvette! Fact: The wiring harness was melted, yes, but that doesnt mean it was actually shorted. Therefore, it wouldnt throw a code. I now know the wiring isnt the main problem. It seems like another issue was arising such as a fuel filter problem.
It is safe to assume that everything I have said I've done has been done correctly. With that said, I am here for suggestions & help, not sarcasm.
I have explained these issues (in person) to Chevy TECHNICIANS and even they do not know whats going on. They have even told me things contradicting facts from you guys on this forum which is pretty sad on their part (e.g. "the car wont run with the oil level sensor unplugged). I had my car RUNNING with it unplugged later that day! Unfortunately, they will be the ones "fixing" my car if I dont get help on here.
Thanks in advance
Thanks in advance
7th Gear
I HAVE CODES NOW
Today I went to unlock my car and it starts freaking out like a relay was going. So I went to O'Reilly and had the battery tested. Battery (3 years old) is "fine" even though it was almost dead and I had charged it fully the week prior.
What I think is happening is something must be draining the battery very quickly and then the computer freaks out when its low.
After I put in the fully charged battery, I was able to get 4 codes (all 40-BCM module):
B0503 H (RH DRL Relay Circuit)
B0508 H (LH DRL Relay Circuit)
B2483 H (Backup lamp relay circuit)
B2528 H (Horn relay circuit)
I still have the "low oil level" warning, BUT MY CAR NOW RUNS with the fully charged battery. ???
Any ideas guys?
Any ideas guys?
I HAVE CODES NOW
Any ideas guys?
Any ideas guys?
I suspect you have a battery with an intermittent internal short. A lead acid battery can seem perfectly fine one second and then dead as door nail the next.
If the battery was allowed to go completely dead, it should be replaced regardless.
