Vacuum Lines diagram under battery tray?
Looking for some help with two vacuum lines that I found loose in the passenger front fender under/near the battery tray. One appears to be about 8-10" long slight curve at one end, and has a 90* rubber elbow on the end. IF I can figure out that one then the other one would just be process of elimination. The other one goes into the wire bundle that goes through the firewall near the HVAC.
Thanks in advance.
Thanks in advance.
This is an old thread but it's new to me.
Is it safe to assume that the vacuum lines joined together with a tee from a vacuum source? (one vacuum line teeing to supply 2 requirements?)
Thanks for this forum, I never would have gone looking here to fix the P0410.
Stu.
Stu.
