Input size opening of a LS2 Throttle Body ? (Coupler size needed?)
Old 10-10-2011, 09:32 AM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Default Input size opening of a LS2 Throttle Body ? (Coupler size needed?)
Guys:
I am working to put together a FAST 92, and a LS2 Throttle body setup for my 04 Z06.
The RED Silicon coupler that I have going into my stock LS6 Throttle (78mm) body has an Inner diameter of 4" (10cm).
Below is a picture of my RED 4" inner diameter coupler that I have mounted to my stock LS6 throttle body now.
Will this 4" silicon coupler work with a LS2 throttle body ? Or will I need a larger size coupler ?
Thanks !
Toque
[/QUOTE]
Old 10-11-2011, 10:29 AM
Mike04
Mike04's Avatar
4" is what I have on my LS3 TB, you should be fine.
Old 10-11-2011, 11:23 AM
Toque
Toque's Avatar
Thanks !
To Input size opening of a LS2 Throttle Body ? (Coupler size needed?)
Quick Reply: Input size opening of a LS2 Throttle Body ? (Coupler size needed?)
