Procedure to install a FAST 92 INtake Manifold (For Dummies like myself)
Old 10-17-2011, 05:38 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Default Procedure to install a FAST 92 INtake Manifold (For Dummies like myself)
Guys:
Looking for an official install procedure for the FAST 92 intake manifold. Preferably for dummies like myself.
Thanks !
Toque
Old 10-18-2011, 08:51 PM
SR-71
SR-71's Avatar
It's pretty straight forward Mark. Just make sure you have the pigtail adapter for the TB and a coolant bypass(homemade or bought) since the bigger TB's don't have coolant passages. Also the mounting bolts for the TB are different. You might look up an LS6 intake install, the basics should be the same. It's been awhile since I installed mine but I don't recall any issues.
Old 10-18-2011, 09:24 PM
Toque
Toque's Avatar
Thanks !
What about the fuel line. Special tool to remove that ?
I am already planning to get the pigtail adapter for the LS2 TB, and already have the TB bypass on my car now.
Toque
Old 10-19-2011, 08:53 AM
SR-71
SR-71's Avatar
Yeah the fuel line takes a little tool to pop it apart. They sell sets of them them at advance/autozone for about 10 bucks. Think they are fuel line/AC line tools.
Old 10-19-2011, 09:04 AM
Toque
Toque's Avatar
Thanks Bro !
Old 10-19-2011, 09:08 AM
mchicia1
mchicia1's Avatar
Those are the easy parts.
Don't forget to replace your valley bolts with button top bolts.
Also, you will probably need to relocate your map so it doesn't hit the firewall. I like this method because it is cheap and keeps the map in the back.
http://forums.corvetteforum.com/c5-t...on-photos.html
Old 10-19-2011, 09:16 AM
Toque
Toque's Avatar
Good info... thanks !
Button top bolts come in the FAST kit ?
Toque
Old 10-19-2011, 09:18 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
If it is not already ported, you might as well get that done before you install. Make sure to use the button top bolts.
Old 10-19-2011, 09:36 AM
Toque
Toque's Avatar
I got SpinMonster lined up to paint and port...
Button top bolts come with the FAST ? Or elsewhere ?
Toque
Old 10-19-2011, 09:51 AM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Awesome you will see a nice jump in power across the whole band! Great move!
Old 10-19-2011, 09:57 AM
Toque
Toque's Avatar
I'm hoping so.... See what it can do to my already 448rwhp/432rwtq...
I'm hoping for around +15 (463rwhp/447rwtq).
Toque
Old 10-19-2011, 12:08 PM
SR-71
SR-71's Avatar
The bolts came with mine when I bought it.
Old 10-19-2011, 02:57 PM
Toque
Toque's Avatar
Cool ! Mine should too then.
Toque
Old 10-19-2011, 03:08 PM
chassed
chassed's Avatar
What does your car make right now with the cam only set up?
This intake should give you nice gains.
Old 10-19-2011, 03:14 PM
Toque
Toque's Avatar
I have heads too...
The following setup gave me 448/432 (With stock Z06 wheels/tires).
I'm going to dyno with my friends stock Z06 wheel's to better gauge the gain (more apples to apples that way).
Vararam B2 w/Green Filter
Airbridge & Smooth Tube
Shanner Polished & Ported Throttle Body
Throttle Body By-Pass
AFR 205 Heads Milled to 59cc for >11.1 comp ratio
Comp 921 Dual Valve Springs
Comp R Valve Lifters
Hardened Steel Pushrods
Titanium Retainers
ASP Under Drive Pulley
160 Degree Thermostat
LG's G5X1-E Cam on 114 LSA
SVO 30# Fuel Injectors
LG Pro Long Tube Headers With Cats
GHL Bullet Cat Back Exhaust
To Procedure to install a FAST 92 INtake Manifold (For Dummies like myself)
Quick Reply: Procedure to install a FAST 92 INtake Manifold (For Dummies like myself)
