Headlight Control Module Bad...Why?
If HID lights were added they can cause the problem of the motors not closing unless the high beams are selected, this is due to the reduced current draw of the more efficient HIDs. Most owners add power resistors to increase the current draw so the lights will open and close as they did with the old lamps. Did you remove the control module and check it for defects as seen in the above photos such as a warped cover that can let in water?
I located a used on from a used Vette parts online store for (This works for me) $99.00 and free shipping. Now, I will remove the clicking unit and open it and check for moisture inside the unit. May as well silicone the seems of the replacement unit once it arrives.
I will post some photos once I open the currently installed defective unit.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was thinking the same thoughts.. Do you have HID lights????
The module has to sense a specific CURRENT to actually SHUT OFF the power to the head light motors.
You module or the current required to power the motors could have changes just enough to make the control module have LOGIC issues.
Awaiting on your dissection of the module.
Bill
Bill
Reconditioned headlight control modules available
It seems that most everyone buys these things used. I got the shock of my life when the dealer told me these modules cost $675.00 new.
The guy at the parts desk recommend finding a used one at the bone yard or Ebay. My unit is ticking. It is not getting warm. It's only making a ticking sound.
www.top-downsolutions.com
This was after my mechanic had touched the solder joints of my board with a hot iron without luck.
Someone else report that tapping his board caused the lights to move suggesting a bad relay on the board and replaced the relay (soldering required) in 2009 with one from:
The relay is made by Omron, and the part # is MY4-02-US 12VDC.
I have only found it at one source: California Radios Plus, $13 plus $7 shipping.
There is a replacement part made by Omron that is sold by many,
including Mouser Electronics, and it is cheaper than the original
part. The problem is that it has flat terminals on it, and the original
has pins that are soldered to the circuit board. I assume that if you
were a patient sort, you could modify the relay and/or the board to
accept the replacement, which is only $6 plus shipping.
gpruitt54 (02-18-2018)
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The FIRST thing that I recommend doing is checking the little plastic pads that the headlight module stops against when its UP & DOWN. They get smashed/missing and can cause weird issues with the module when the headlight module is stopped.
Sounds like its on the very edge of its TORQUE limit of being seated.
Something simple to try.
Make SURE you reseal the back of that module!
Bill
Bill
Hey guys, I know that's an old post, but I was wondering if one of you guys had a better picture of the circuit. I was hoping to modify that module to work with LED bulbs so the lights go up and down without needing an external resistor.
The timer alternative is here: https://www.corvetteforum.com/forums...ol-module.html
I have been dealing with my module in a 1998 corvette to try and fix it and would like to share some info I got. It may help you to replace components, test resistors, diodes and capacitors and to eventually make a new board (layout and gerber file included - I used Sprint Layout 5 to copy the tracks of the board). I couldn't find a place to buy the replacement for the "board inserts" (male plug), for the Omron relay (even though MY4 are easy to find, but not 9V) and the proprietary GM controller (made by ON Semiconductors). Eventually I am going to prepare the case for 3D printing and share the file.
Showing resistance measured at each resistor.
resistors:
R1 - 325 ohms (330 ohms - orange/orange/brown/gold)
R2 - 325 ohms (330 ohms - orange/orange/brown/gold)
R3 - 8k ohms (8.2k ohms - grey/red/red/gold)
R4 - 7k8 ohms (8.2k ohms - grey/red/red/gold)
R5 - 7k8 ohms (8.2k ohms - grey/red/red/gold)
R6 - 8K ohms (8.2k ohms - grey/red/red/gold)
R7 - 116k3 ohms (120k ohms - brown/red/yellow/gold)
R8 - 17k53 ohms (18k ohms - brown/grey/orange/gold)
R9 - 323k ohms (330k ohms - orange/orange/yellow/gold)
R10 - 98.6 ohms (100 ohms - brown/black/brown/gold) - became black -> a resistor with more Watts (eg. 1W or 5W) would be better.
R11 - 116k3 ohms (120k ohms - brown/red/yellow/gold)
R12 - 116k4 ohms (120k ohms - brown/red/yellow/gold)
R13 - 118k6 ohms (120k ohms - brown/red/yellow/gold)
R14 - 46k4 ohms (47k ohms - yellow/violet/orange/gold)
R15 - 46k4 ohms (47k ohms - yellow/violet/orange/gold)
capacitors:
C1 - 104K 5K tantalum? - 100nF (used for pin 6 of IC)
c2 - 105k 250v poliester (1000 nF) (used for pin 2 of IC) - VSS?
C3 - 103K Y5R 50V ceramic (10 nF) (used for pin 9 of IC)
C4 - 103K Y5R 50V ceramic (10 nF) (used for pin 7 of IC)
diode:
D1 - 1004 0348A
D2 - 1004 0348A
D3 - 1004 0348A
D4 - 1004 0348A
transistors:
Q1 - BUZ11a (morocco ST 31F 410) - controls the flow of currrent of one side
Q2 - BUZ11a (morocco ST 31F 410)
Q3 - f D345 7621
Varistors:
VAR1 - 07 k14 0348
VAR2 - 07 k14 0348
Relay:
RLY1 - Omron MY4-UA-006426 - 9VDC - 5A 28VDC - 5A 240VDC - 16509987
jumpers:
F1
F2
Controller:
IC1 - 16512455 UEN00403 ON -
pins:
1 - gnd
2 - VSS? linked through R10 to (+) and to pin 6 via R9. Have C2 to estabilize.
3 - n/c
4 - controls the opening of Q3 via (-) - relay power
5 - linked to pin6 via R8
6 - linked to pin 2 via R9. Have C2 to estabilize.
7 - input from headlights ON state
8 - gnd
9 - input from headlights OFF state
10 - gnd
11 - input from drain of Q2 - senses if Q2 was opened. Goes through R6
12 - connected to (+) through R3
13 - connected to (+) through R5
14 - input from drain of Q1 - senses if Q1 was opened. Goes through R4
15 - controls gate/opening of Q2 - energy (-) to F2 that feeds the relay. Goes through R14
16 - controls gate/opening of Q1 - energy (-) to F2 that feeds the relay. Goes through R15
Connector pins:
(9x) 2.8mm (1/8") insert pcb / 30mm height / 0.9mm thickness
(to be replaced by wires leading into a male connector)
Black plastic Base for connector:
1x base - 12mm height 9mm width 29mm large (4pins)
1x base - 12mm height 9mm width 37mm large (5pins)
resistors:
capacitors:
diode:
D1 - 1004 0348A
D2 - 1004 0348A
D3 - 1004 0348A
D4 - 1004 0348A
transistors:
Q3 - f D345 7621
Varistors:
VAR1 - 07 k14 0348
VAR2 - 07 k14 0348
Relay:
jumpers:
F1
F2
Controller:
pins:
1 - gnd
3 - n/c
8 - gnd
10 - gnd
Connector pins:
The following 3 users liked this post by rdelboux:
equivalent for Q3 - f D345 7621
in my device i have the (Q3 - f D345 7621) looks damaged but i can not find it in any market. even no any result on google search for (f D345 7621). so can you advice me what equivalent i could use instead of it.
It appears to be a designed PC board from back of the day when "sparkys" were developing PC design . Give them "sparkys designers"a break Bunkey! Where were you in 1989.. with your skate board?
I'm having issue with mine now, I was quoted $1500 with labor to replace the module, left side headlight motor, & headlight wiring harness. I'm looking for less expensive options.
