Emer. Flashers work, Turn Signals don't
Old 11-15-2011, 10:19 AM
Blue Blood
Blue Blood's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Default Emer. Flashers work, Turn Signals don't
2002 Z06, I have LED's installed for some time, with an aftermarket flasher to deal with hyper-flash and this last weekend I realized that my lights are not illuminating for the turn signal. I can hear the flasher switching, but no lights on the instrument panel or at the signal lights. If I activate the emergency flasher everything works as it should. Is there a specific fuse for the turn signals, or do I just need to replace the flasher?
Thanks, Clint
Old 11-15-2011, 09:57 PM
Blue Blood
Blue Blood's Avatar
No thoughts from anyone?
Old 11-15-2011, 09:59 PM
Caesar68
Support Corvetteforum!
Caesar68's Avatar
Change your hazard switch located in the dash. This is most likely the problem.
Old 11-16-2011, 09:42 PM
lionelhutz
lionelhutz's Avatar
The aftermarket flasher has likely failed.
Peter
Old 11-16-2011, 10:45 PM
95BlueBomber
95BlueBomber's Avatar
Been there... changed the flasher and voila it was fixed
Old 11-16-2011, 11:39 PM
Blue Blood
Blue Blood's Avatar
Flasher was my thought as well. Didn't see how the hazard switch would really be a problem in that it sees absolutely no action, and the hazard lights work.
Thanks, CC
Now if I can just figure out the correct replacement without taking this part out first....
To Emer. Flashers work, Turn Signals don't
Quick Reply: Emer. Flashers work, Turn Signals don't
