Passenger window stuck down, grinding noise
Ok, so I currently have my door trim panel off and the speaker removed so I can access the window but I can't figure out what's wrong!! When I push the window to go up or down nothing happens with the window itself. The motor sounds like it's working, but theres a grinding noise and I can see the cables getting loose on the pulleys near the top of the door trim.
Any advice or others experiences appreciated!
I had this problem, it is an easy fix. Its the regulator and you need a new one. It will take about an hour and a half. Just take your time and it will be fine. If you have a service manual the steps are easy to follow. One key is to mark where the window is, trace around the clamps. This will help you in adjusting the window.
took me 30 minutes, most of that was adjusting the height of the window when its closed. First time it wouldn't sink into the little rubber seal, second time was a charm. Very good video on youtube about how to do it. I watched it three times, then said **** it. Went and did it. Now onto the flasher bypass and hazard switch.
