[PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
Old 01-10-2012, 10:59 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Originally Posted by Lifted07Sierra
Where is the top line of what is it the catch can? Where is that line going, it looks to be going underneath the intake.
Also after you got yours on did you notice it defintely needs a retune because its acting alil funny?
Mine is atleast
The top line of the catch can goes into the Engine Valley cover.
I have not driven my car with the Fast on there. It will be too lean for me to consider driving. I hope to get a tune at LG's in the next week or so. Lucky for me they are only 5 mins from my house...
Toque
Old 01-12-2012, 09:57 AM
tsbbzm
tsbbzm's Avatar
Originally Posted by R6cowboy
This write-up is excellent. Well done
Originally Posted by 0H1Z06
Awesome write up, even a more awesome car and a pretty good guy!!
Originally Posted by QCVette
Any idea how much hp you gained with the upgrade?
Old 01-12-2012, 01:16 PM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
If you can find a trailer, i'll bring my truck and haul you over there Mark. LMK if i can help....
Toque
Old 01-12-2012, 01:42 PM
Toque
Toque's Avatar
Thanks Matt... I think i'm close enough I'm not going to worry about it too much..
Toque
Old 01-13-2012, 12:06 AM
printmanjackson
printmanjackson's Avatar
St. Jude Donor '06-'07-'08-'09
why don't you guys buy tuning software like HPTuners and learn how to tune? It's really not as hard as you think
Old 01-13-2012, 08:15 AM
Toque
Toque's Avatar
That's something I have been thinking about to be honest with you. I would like nothing more than to "really" dial my car in myself with my laptop driving around.
Toque
Old 01-13-2012, 10:27 AM
Corvette-Chris
Corvette-Chris's Avatar
St. Jude Donor '08
I wish I would have done this when I had a stock car, then H/C/I, then nitrous, now TT. I see your point, but it's not the easiest thing to do when you jump in and want to tune a TT car with multiple boost settings, methanol, etc. LOL
Toque
I always enjoy your write-ups and how descriptive and picture oriented they are, even though I feel I'm very good with a wrench and don't need them (I say that as humbly as possible, seriously). However, I do realize that there are TONS of people out there that do. Keep it up man!
Old 01-13-2012, 08:02 PM
Toque
Toque's Avatar
Guys:
So I pulled 471/441 today. Up from 451/427. Not too shabby. I'm impressed and the car feels good ! A constant gain from 3500rpm all the way to red line.
Toque
Old 01-13-2012, 08:04 PM
Toque
Toque's Avatar
Thanks Chris !
Toque
Old 01-13-2012, 08:15 PM
J0KER
J0KER's Avatar
Guys:
Toque
Not too shabby, indeed! Great numbers, Toque!
Old 01-13-2012, 08:19 PM
Lifted07Sierra
Lifted07Sierra's Avatar
Maybe I missed it but where are your mods listed at?
Old 01-13-2012, 08:53 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Guys:
Toque
Very nice indeed, does this additional power have you thinking about 500?
Old 01-13-2012, 09:08 PM
  #33
Toque
Toque's Avatar
No... Engine mods are done for me. Only thing stock on the motor is the block and rotating assembly. I only have a small drivers cam in there and I love the drivability of it. I don't need to be the fastest guy on the block. I have enough friends that I live vicariously thru them... 471/441 is plenty for me.
My web site... www.ToqueZ06.com
Toque
Old 01-14-2012, 12:54 AM
  #34
Toque
Toque's Avatar
Here are my actual results.
Old 01-14-2012, 10:58 AM
  #35
C7&7
C7&7's Avatar
Very nice Mark.
20 & 14 from a ~ $1000 mod is pretty good in the corvette market.
Curious where the injectors were though? Were you able to get the duty cycle?
Old 01-14-2012, 12:18 PM
  #36
Toque
Toque's Avatar
Originally Posted by Tim05C6Z51
Very nice Mark.
Thanks Tim !
80% at WOT. I'm not at WOT very often so I should be fine. If I add any more power I will get higher injectors.
Toque
Old 01-14-2012, 12:42 PM
  #37
ctusser
ctusser's Avatar
Very good stock cube combination with a mid range cam. With an aluminum flywheel and big cam you'd be right aroung 500whp. But that would just be for bench racing bragging rights as it wouldn't drive nearly as well and might not actually be any faster.
To [PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
Old 01-14-2012, 01:59 PM
  #38
C7&7
C7&7's Avatar
It would take a lot more cam to hit 500. Something in the high 230s and low 240s. He does have an aluminum flywheel actually.
Old 01-14-2012, 04:11 PM
  #39
ctusser
ctusser's Avatar
Agree especially knowing he has aluminum flywheel already; but 18lb sounds more like a steel one than aluminum. I guess an EWP would show a little more if that's not on there. Just complimenting such good results for a nice drivable build on stock cubes.
Old 01-15-2012, 03:42 AM
  #40
Toque
Toque's Avatar
Guys:
So tonight I shaved my engine covers and got a perfect fit.
To shave the engine covers you will need the following.
I got a 2" drum sanding wheel with 80 Grit sand paper and used my drill.
You can see the BEFORE covers on top, and the AFTER covers on the botttom.
The 2" drum sanding wheel fits very well for the angles I was trying to achieve.
What I did was install the cover, make marks where it needed to be sanded, and started sanding.
I would then re-install the cover and make more marks where it needed to be sanded, and started sanding again.
I continued doing this over and over and over till I got the shape I was looking for.
I went slow with it so as not to over sand any given area.
I wanted it to look like it was designed to fit the intake from the factory.
I made sure that the covers snapped into place and there was adequate clearance around the intake.
After I achieved the fit I wanted, I went back and used 400 grit sandpaper smoothed the cut edges.
This is how the Passenger side fits after sanding.
This is how the Driver side fits after sanding.
Ready to hit the streets !
Toque
Quick Reply: [PROCEDURE] - Fast 92 Intake, and LS2 Throttle Body Install (C5 Corvette)
