[PROCEDURE] - C5 Corvette HVAC Dim Display Fix
Old 07-07-2014, 08:11 AM
  #41
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Originally Posted by Ticket Magnet
The lights for the buttons when the headlights are on. The amber indicator lights still work normally. It is the backlighting when the lights are on. Nothing to do with soldering the resistors and the now working HVAC LED display. Just my fumbling of all the buttons and the rubber backing that may have broken something.
Ticket Magnet
Its hard to say whats wrong.
You may want to send it off to repair.
I'm not sure who repairs these though...
Maybe someone watching this thread does ?
Sorry
Toque
Old 07-07-2014, 04:03 PM
  #42
Bajapit
Bajapit's Avatar
Thanks for Posting. Ill be on it. Do you know if the bulbs are 12 volt.
Old 07-07-2014, 04:25 PM
  #43
Toque
Toque's Avatar
Originally Posted by Bajapit
Thanks for Posting. I, on it. Do you know if the bulbs are 12 volt.
Yes the bulbs are 12v
Toque
Old 07-07-2014, 05:44 PM
  #44
dadaroo
dadaroo's Avatar
Radio Shack 272-1092 bulbs are a perfect match to OEM. Need to know how to solder.
Old 07-07-2014, 06:31 PM
  #45
Smoken1
Support Corvetteforum!
Smoken1's Avatar
I tried the 1092 bulbs but found these a better choice Radio Shack #272-1154.
Used them in the cd player also
Old 07-07-2014, 10:40 PM
  #46
Bajapit
Bajapit's Avatar
Thanks YOU GUYS are Great. I and I know Others Appreciate those who go first and share the knowledge. Some of these tasks are Fun to some of us.
Old 07-08-2014, 02:17 AM
  #47
Ticket Magnet
Ticket Magnet's Avatar
Originally Posted by Toque
So whats not working now ? The LED display ? The lights for the buttons ?
Toque
Sorry
Toque
No need to apologize. I lived with no LED display so this issue is very minor. Next time I take it apart I will take a look.
Thanks again,
Ticket Magnet
Old 07-08-2014, 06:44 AM
  #48
dadaroo
dadaroo's Avatar
Curious, was it the brightness or color you liked about the 1154 bulbs?
Old 07-08-2014, 12:34 PM
  #49
Bajapit
Bajapit's Avatar
Should I be able to test the Individual lights one at a time with a 12 volt source from the solder side of the board. I have tried but absolutely none have worked.
Old 07-08-2014, 01:10 PM
  #50
Smoken1
Smoken1's Avatar
They all could be out all but 1 of mine where. As for a difference in the 2 bulbs both cars looked about the same. Just the 1154's did not have the micro fine wires that the 1092's have and thats what he brought me to use
Old 07-08-2014, 07:15 PM
  #51
Stainsy
Stainsy's Avatar
Just like to thank you Toque for the excellent instructions, and pictures as to how to fix that little display problem. Worked great, and for the first time since I have owned the car, I can now see the display. Thanks again
Old 07-08-2014, 09:12 PM
  #52
Toque
Toque's Avatar
I'm glad to hear it worked for you !
Toque
Old 07-09-2014, 10:04 AM
  #53
Bajapit
Bajapit's Avatar
I did both re-solder and all 14 lamps, all burned out. worked great. Picked up the bulbs from Batteries Plus Bulbs.. All 14 in stock.
Old 07-09-2014, 07:23 PM
  #54
tbrent
tbrent's Avatar
2018 C5 of Year Winner
Very nicely done Toque. Your write ups are the best one stop shop for folks looking to fix or service their C5. Thanks for all your efforts
I am wondering if this will help my hvac. Everything is fine except for the indicator led on the "AC" button is very dim. I had my lighting changed out by tstar years ago but wonder if it's this need for new solder that has the one light so dim.
Great post.
Old 07-10-2014, 08:36 AM
  #55
Toque
Toque's Avatar
Great post.
Thanks !
If you had LED's installed, and one is dim then I would suspect:
1.) Its not aimed correctly inside the botton. I had to aim mine a bit for max brightness
2.) Solder connections can go cold after time. Touching it up could help.
3.) Replace the LED behind that button. It might just be a bad LED.
Toque
Old 07-10-2014, 09:51 AM
  #56
tbrent
tbrent's Avatar
Thanks !
Toque
Thanks my man Much appreciated. Man, the little projects never stop But I am like you, it's fun to tinker with the ride
Old 07-10-2014, 09:52 AM
  #57
Toque
Toque's Avatar
Anytime !
And tinkering is fun !
Toque
To [PROCEDURE] - C5 Corvette HVAC Dim Display Fix
Old 07-11-2014, 10:34 PM
  #58
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
Thanks for reposting this. Is about time I get off my *** and do this.
Old 07-13-2014, 05:05 PM
  #59
Catman58
Catman58's Avatar
Thanks Toque. Just got done doing mine did you know it is 87 degrees outside here in the panhandle of Nebraska? First time I have been able to see the display without having to be 2 inches from it since I bought my C5. This is a great forum with great information and people
Old 07-13-2014, 05:16 PM
  #60
Toque
Toque's Avatar
Sweet ! ! !
Toque
Quick Reply: [PROCEDURE] - C5 Corvette HVAC Dim Display Fix
