Valvoline Transmission Fluid - Rough after change - anybody?
Old 03-12-2012, 06:19 PM
pvknight
pvknight's Avatar
Default Valvoline Transmission Fluid - Rough after change - anybody?
Hi all,
I have a 1998 Coupe. Just changed the 6-speed manual transmission fluid this weekend, only 42k on the car, not driven much by the previous owner. I went with Vavoline ATF DEX/MERC. I used the same stuff on my last corvette without issue.
After the fluid change I noticed:
1) no improvement in shift quality
2) a noisy throwout bearing sound ~1500rpm
3) a rough clutch engagement at higher rpm shifts (4000+)
Has anybody else had experience with this fluid? Recommended alternatives?
Thanks,
-Brian
Old 03-12-2012, 06:57 PM
RaW Z06
RaW Z06's Avatar
Drain that crap out of your transmission.
Go to your Local GM dealer and Purchase 4 qts of Manual Transmission Fluid (GM # 88861800)
This is the correct fluid for your tranny.
Old 03-12-2012, 07:03 PM
injun.724
injun.724's Avatar
Default pennzoil
Use Pennzoil Synchromesh. Excellent shifting with no notchiness.
Old 03-12-2012, 07:08 PM
baxsom
baxsom's Avatar
manual calls for ATF in the MN6. did something change? amsoil TQD is also an excellent alternative
Old 03-12-2012, 07:55 PM
pickleseimer
pickleseimer's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Had the same issue after using Royal Purple Max ATF. Shift into third would catch a tooth or two while cold but went away after a few miles.
Called Tremec last week, talked to their rep (named Rob), and asked what should be used in my '01 MN6. He said Mobil 1 Synthetic ATF is what Tremec recommends, and that is also good for the paper blocker ring versions as well (surprising given all the internet smack downs on synthetic ATF and paper blockers).
Drained the RP - only had 200 miles on it - installed the Mobil 1, and the difference is remarkable - smooth shifts and no synchro issues.
Old 03-12-2012, 08:49 PM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Alternative I've been using in my track day car for years with no problems:
AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 03-12-2012, 09:34 PM
johnson-rod
johnson-rod's Avatar
Old 03-12-2012, 10:50 PM
pvknight
pvknight's Avatar
Thanks for all the responses, it's very helpful in addition to all the threads I've searched and read.
Noise:
I'm not experiencing a grind going into any gears, but rather a "growl" from the tunnel/shifter area as I accelerate past 1400-1600rpms. Very noticeable when cold, but it goes away once the car (transmission) warms up. Weird.
Feel:
Here's a question. When you guys depress the clutch pedal to shift at RPM's above 3500, do you "FEEL" the engine spinning/working through the pedal as you engage the clutch?
Other cars I've driven had pretty "harsh" clutch feel in the upper revs, but I remember the vettes had a very SMOOTH and ISOLATED feel regardless of how hard the engine was working.
-Brian
Old 03-12-2012, 11:44 PM
RaW Z06
RaW Z06's Avatar
The book Calls for Dexron III
Dexron IV is backwards compatible for Auto's but not for Manual's.
GM specifically recommends Manual Transmission Fluid #88861800
Old 03-12-2012, 11:50 PM
pvknight
pvknight's Avatar
Good info. Though the dealer here seems to have Dexron III ATF listed for my '98 6-speed, but the 88861800 for the newer C6 vettes - ?
Maybe the Z06 trannies can take the MT fluid? Seems the 98-00 transmissions are more picky.
ps enjoying the Ti's VERY much
Old 03-14-2012, 08:12 PM
RedZMonte
RedZMonte's Avatar
I swapped my stock fluid out for Valvoline Dex III without any issues. shifts just like stock. I didnt notice any difference one way or another other, the stock fluid was 30K miles old on a '04 and dirty as heck. Dex VI is not compatible with the 6spds, must be Dex III or GM MTF, I read that the GM MTF is rebottled GM DEX III ATF. I have never tried GM SyncroMesh or Pensoil SyncroMesh... but i have heard of other car guys out there using GM Syncromesh in their cars (Honda, subaru, ect..) with good results.
S
Old 03-15-2012, 10:33 PM
pvknight
pvknight's Avatar
Originally Posted by RedZMonte
...I read that the GM MTF is rebottled GM DEX III ATF....
seriously??
I used Valvoline DexIII a few years ago on my '00 FRC, and it was great. Smoother, quieter shifting and driving.
But, I think Valvoline has changed it to a DEX/MERC hybrid now, so that they can sell to the Ford guys too. Seems the quality was compromised...
and, GM DexIII is hard to come by at the dealers around here...
Old 03-16-2012, 06:16 AM
Cybermind
Cybermind's Avatar
The difference in shift quality was remarkable when I changed my OEM tranny fluid to Mobil 1 Synthetic ATF. I highly recommend it.
Old 03-16-2012, 06:01 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Not trying to hijack the thread, but I changed my tranny fluid yesterday, for the second time, in my '01 coupe. The first time I changed it, I looked somewhere or other, and based on what I found, I think I bought 5 quarts of tranny fluid. I drained it through the drain plug, refilled it until it was almost dripping out of the fill hole, but had 2 quarts left over.
That was around 2004, and I had a couple changes occur in my life, and along the way, I had to get rid of a lot of "extra stuff", including the extra bottles of Dex III fluid. I admit that my memory isn't all that great, so when I ordered fluid again, I didn't remember exactly what I previously used, and what I had to get rid of, so I once again ordered what the reference material said, 5 quarts.
Once again, I have 2 quarts left over. Anybody know what's up with this? I understand that in an automatic tranny, the torque converter and cooling lines retain a certain amount of fluid, so there's a "dry fill" fluid capacity, as well as a "filter change" fluid capacity. I've never seen a manual tranny that "holds fluid"....
Old 03-16-2012, 07:09 PM
Oldvetter
Oldvetter's Avatar
I use Amsoil TOD (Torque Drive), it is about $50 a gallon.
DO NOT use Mobil 1 ATF with 1997-2000 C5s, due to their paper blocker rings. I did and after 50,000 miles my trans started grinding going into 5th and 6th gears. A change to Amsoil Torque Drive stopped it immediately !
Old 03-16-2012, 09:35 PM
johnson-rod
The first change I went with autozone DextronIII and it didn't feel any better than the 10 year old DextronIII from GM. The next year I went with Amsoil Torque Drive and it was like 'budda'.
Old 03-17-2012, 08:13 AM
leadfoot4
leadfoot4's Avatar
Probably because the Autozone Dex III isn't a synthetic fluid, whereas the Amsoil is.....
FWIW, I've use Red Line's synthetic Dex III.
To Valvoline Transmission Fluid - Rough after change - anybody?
Old 03-17-2012, 09:42 AM
baxsom
baxsom's Avatar
My manual on page 7-19 specifically says automatic transmission fluid for both automatic and manual transmissions. What is the difference between GM MTF and Dexron III?
Old 03-17-2012, 10:12 AM
RaW Z06
RaW Z06's Avatar
2007 GM TSB#04-07-30-037D clearly states, "Any vehicle that previously required DEXRONŽ-III for a manual transmission or transfer case should now use P/N 88861800".
Hope this helps
Old 03-18-2012, 01:38 AM
pvknight
pvknight's Avatar
Hope this helps
Thanks, very helpful! Changed to the MT this weekend
Quick Reply: Valvoline Transmission Fluid - Rough after change - anybody?
