How to change rpm idle on Ls3 engine?
Old 04-12-2012, 12:07 PM
Red Rochester
Red Rochester's Avatar
Default How to change rpm idle on Ls3 engine?
How do I increse the idle on my 08 C6?
Old 04-12-2012, 01:45 PM
mmartinez
mmartinez's Avatar
Tune
Old 04-12-2012, 02:42 PM
dougbfresh
dougbfresh's Avatar
Same way you do on any EFI engine-you have to reprogram the engine control computer with the new idle speed.
Old 04-12-2012, 08:23 PM
Paul 75 L82
Paul 75 L82's Avatar
Some hand held programmers will re set idle.
Old 04-13-2012, 01:40 PM
099blancoss
Former Vendor
99blancoss's Avatar
St. Jude Donor '10-'11-'12
programming
Old 04-13-2012, 08:12 PM
doje
Support Corvetteforum!
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by mmartinez
Tune
Originally Posted by 99blancoss
programming
And maybe post in the C6 section rather than the C5 section.
Old 04-13-2012, 08:20 PM
David426
David426's Avatar
Idle screw should be on the drivers side of the carburetor..
Old 04-13-2012, 08:22 PM
doje
doje's Avatar
Originally Posted by David426
Idle screw should be on the drivers side of the carburator..
Old 04-13-2012, 09:19 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DOUBLE
The real answer is TUNING! You need to change the PCM idle setting cause you have a throttle by wire system.
BC
To How to change rpm idle on Ls3 engine?
Quick Reply: How to change rpm idle on Ls3 engine?
