Zinc-plate rotors
Old 07-06-2012, 10:26 PM
GPASC5
6th Gear
GPASC5's Avatar
Default Zinc-plate rotors
What are the pros & cons of zinc-platting new rotors, Have new set of AC Delco drilled/slotted rotors, and concerned about dampness causing rust.
It has also been suggested that Zinc Platting can warp new rotors due to 800 degres of dipping process, and plugging up drill holes.
Any info on zinc platting would be appriecated, do not want to damage rotors before they get on car ( 1999 C5)
Old 07-06-2012, 10:31 PM
slant
slant's Avatar
I can't imagine having any issues.
Old 07-06-2012, 11:06 PM
hornet7
hornet7's Avatar
Default Rotors
Mine are plated and no problems. I like the look of my rotors. no rust!
Old 07-06-2012, 11:23 PM
PHILLY JOE
PHILLY JOE
Support Corvetteforum!
PHILLY JOE's Avatar
Not a problem on mine// 2002 z06
Old 07-07-2012, 09:03 AM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I really can't see how rust on the rotors is of any great concern.
As long as the rotor "hats" are painted, any rust that forms on machined braking surface will wear off the next time you apply the brakes.
I would just put a good coat of high temperature paint on the rotor hats, and install them on the car without zinc plating them.
Old 07-07-2012, 01:07 PM
Old Horsepower
Old Horsepower's Avatar
I like the rotors from Brake Performance. And their Zinc plated. They work great and no rust.
Old 07-07-2012, 02:28 PM
Old Horsepower
It wears off in about 15 - 20 miles. So only part that can rust is pad contact area. So every time you brake it is cleaned. If that is not what your looking for I have seen plating that does not come off ( maybe copper) but its more for show I think.
Old 07-08-2012, 01:30 AM
NukeC5
NukeC5's Avatar
The zinc plating works fine. It makes a much cleaner look than some of you would think. Every bit of the rotor not touched by the pad stays bright and shiny. The outside edge of the rotor is noticable and the drilled and slotted areas do not rust out. I like mine alot. The plating is not meant for the surface area anyway, just everywhere else that shows (and even doesnt show). Its nice taking off a rotor that has no rust or build up on the back sides or anything.
Old 07-08-2012, 07:13 AM
tentuna
tentuna's Avatar
Same experience, no rust and brakes feel and stop great, I recommend their product and the cost is fantastic.
To Zinc-plate rotors
Quick Reply: Zinc-plate rotors
