bump steer kits for lowered c5's
A QUICK QUESTION FOR THOSE WHOM HAVE LOWERED THEIR CARS-DO ANY OF YOU HAVE ANY PROBLEMS W/BUMPSTEER AFTER LOWERING YOUR C5'S? I ASK BECAUSE I'VE NOTICED THAT SOME AFTERMARKET RETAILERS SELL "BUMPSTEER KITS" I WANT TO LOWER MY CAR AND I'M WONDERING IF THESE KITS ARE NEEDED. PLEASE BEAR WITH ME I'M NEW TO THE FORUM SO IF THIS IS A REDUNDANT QUESTION I APALOGIZE :conehead
Re: bump steer kits for lowered c5's (nassau-hardtop)
I have the longer bolts in the rear, and I cut the fronts down ( 2 sections off ) and I have no problems. Give it a shot I see no reason for it. I recommend a alignment though. Good luck!! :D
My car is very low, and I do have the "bump steer kit", which is really adjustable outer tie rod ends. This allows the geometery of the fron suspension to remain as it was, even after lowering. I drove 6 months lowered before getting it, and have not noticed a huge difference, but the tech who installed it when doing an alignment for me said it was a good idea, and that they were quality parts. Bought mine from Shawn at LAPD for $150.00. Hope this helps.
Greg
:cool:
Greg
:cool:
My car is lowered. I did not feel that I need the "bump steer kit" which is just an adjustable tie rod end. Until that is, I got it installed. On normal highway stuff I do not notice the difference, but at the track and at autocross events on imperfect surfaces I definiely say it makes a difference.
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
bumpsteer is the toe in changing as the suspension moves up and down. once you change the angle of the tie rods and they are not inline with the A frames you will get bumpsteer. :chevy
1 Post
Cruise-In I Veteran
Re: bump steer kits for lowered c5's (MelloYellow)
the bump steer will be hard to measure with the spring in place because the suspension must move up and down thru the whole travel without the frame moving. :chevy
First Vette for me, and one of the first things I noticed is the bump steer on my stock height new C5. I plan on lowering, so it appears it will get worse. Not good in my book. You would think the engineers would not have included this free option. Guess I'll be looking at shelling out some coin for a "bump steer" kit before I lower.
Re: bump steer kits for lowered c5's (clem zahrobsky)
