Need 2002 MAF pin-out !
The stock 2000 MAF have a 3 pin connector and the IAT sensor mounted to the side of the airbridge have a 2 pin connector. Looking at the 2000 documentation this is the pin-out:
MAF:
A YEL MAF Signal
B BLK/WHT Ground
C PNK +12V
IAT:
A PPL Ground
B TAN IAT Signal
Now I will install a 2002 MAF with a integrated IAT sensor. This new MAF/IAT have a 5-pin connector and I need to know the pin-out:
2002 MAF/IAT:
A ?
B ?
C ?
D ?
E ?
Anyone with a 2002 shop manual who could scan the page from the Engine electrical section and email me or maybe fax +46 8 6231856 ?
Your help would be greatly appreciated. Thanks.
:cheers:
MAF:
A YEL MAF Signal
B BLK/WHT Ground
C PNK +12V
IAT:
A PPL Ground
B TAN IAT Signal
2002 MAF/IAT:
A ?
B ?
C ?
D ?
E ?
:cheers:
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Re: Need 2002 MAF pin-out ! (seanr)
Here you go....
A=IAT SENSOR SIGNAL
B=REFERENCE VOLTAGE TO IAT SENSOR
C=GROUND
D=IGNITION VOLTAGE
E=MAF SENSOR SIGNAL
A=IAT SENSOR SIGNAL
C=GROUND
D=IGNITION VOLTAGE
E=MAF SENSOR SIGNAL
1 Post
Cruise-In I Veteran
Cruise-In IV Veteran
There is an adapter available so you don't have to splice, or in case you
want to go back, that is what I used.
Got it from PaceParts.com
Then I changed the MAF table to the Z06 values with LS1 Edit.
[Modified by Flyin'Brian, 7:38 PM 5/27/2002]
Re: Need 2002 MAF pin-out ! (nevrenuf)
Thanks ! :cheers:
I've been offline until now so I just read your posts. I will hook up the new MAF today. Wish me luck :)
I got a cable with a 5 pin connector with the new MAF but no 3pin/2pin connectors in the other end. I will need to cut the old cable but I do not plan to go back to the old MAF :D
Thanks.
:cheers:
[Modified by seanr, 10:42 AM 5/28/2002]
Thanks.
:cheers:
I just received the below info taken from the GM tech documentation. Please note that pin A and B differs from what nevrenuf wrote:
Looks like amazon has the connector you want:
http://www.amazon.com/ACDelco-PT1274.../dp/B000C9QEXG
You do know there are plug-n-play harnesses (off the shelf) to convert to a 5 wire MAF, right?
