Cutouts
Cutouts
does anyone make a cutout that goes inline with no welding...a simple bolton??? cant find anyone to do any welding on the Ti system os the cutouts would work great....
They do make some very short cutouts that can be bolted in. However, that just lenghtens the system and could affect clearances. Try You Tube and search on C5 cutouts. Surely someone around your area can weld your Ti system. If not, you can cut the system and put in a steel flange with short pipe welded to it. Then use a quality clamp to mate it. Not the best approach but could work if you have enough space. Definitley go with guidance from others experience. Hope others weigh in who have done it.
