window relay help
Old 09-12-2012, 01:34 PM
Driwash
Driwash's Avatar
Default window relay help
Drivers door window motor keeps getting hot and window stops working. Door module is okay. Thinking maybe window relays. Would like to know where to get relays or a new window motor. any help would be great.
Thanks,
Tom
Old 09-13-2012, 09:33 AM
Tuscany
Tuscany's Avatar
Something is probably bound up within the motor, regulator, or cabling system. You may or may not be able to clear up the first one or two causes with complete disassembly and a little refurbishing (maybe not, though, because the parts are all plastic), but the cabling issue--seemingly the most common cause--pretty much requires you to replace the whole assembly.
Old 09-13-2012, 09:37 AM
Tuscany
Tuscany's Avatar
Forgot to mention: as far as I know, you can only purchase the entire assembly (motor, regulator, cabling, framework). Someone here just got one recently for a really good price (http://forums.corvetteforum.com/c5-g...regulator.html).
Dunno 'bout the relays, but if the motor is heating up, I don't think the relay is a problem. This suggests the motor's getting the juice but simply unable to turn.
Old 09-13-2012, 09:28 PM
Got uid0
Got uid0's Avatar
St. Jude Donor '17
I bought a replacement from rockauto
After i purchased it i figured out how to repair the motor.
http://forums.corvetteforum.com/c5-t...wr-window.html
If you want to purchase a refurbished driver side regulator let me know.
To window relay help
Quick Reply: window relay help
