Spark plugs
Spark plugs
Hello all,
I've done a search but results were less than helpful. I plan on a wire and plug change soon and wonder; what plug is most favored by everyone? I have no interest in the fancy plugs that I feel do no useful good, except put profit into the manufacturer's pocket. I'm looking for a good solid performing plug that will give good results and decent life.
Thanks.
Scott
Thanks.
Scott
I prefer the NGK Iridium. They are about $8-10 a plug and will last a long time, plus they are supposed to give a more consistant spark.
You would need TR5IX if you are stock or mild bolt ons.
Hello all,
Thanks.
Scott
Thanks.
Scott
NGK v-power are the way to go IMO. They are a standard copper plug, but super dependable and low on the misfires. Only $1.99 a plug in most cases. Gaping them to .050 has given me great results. They wont last as long as iridiums, but I like to change plugs every 30-40k miles anyway.
Actually, nothing. However, I wanted to get the opinion of others before I made a choice. I've had my Vette almost a year now but, the LS engine family is still new to me. I'm old school and there I knew what to use. From what I've seen this engine has needs and wants and I want to make sure I make the right choice. Factory would be fine and may be my final choice. I was just looking for the feelings of others. In your own way, you voted for the factory plug. Thanks.
Scott
Scott
NGK v-power are the way to go IMO. They are a standard copper plug, but super dependable and low on the misfires. Only $1.99 a plug in most cases. Gaping them to .050 has given me great results. They wont last as long as iridiums, but I like to change plugs every 30-40 miles anyway.
Scott
Scott
Scott
Just a word on factory plugs - the ones in my 2000 were JUNK.
Those "double platinum" plugs used a little platinum "puck" welded to the ground electrode, that was notorious for falling off. The two results were that it could possibly catch on a valve seat as it exited the engine, and that it instantly increased the electrode gap about 0.015.
When I removed mine at 15K miles, I found two "pucks" already missing! At some point Delco scrapped that design, as my '08 Caddy platinum plugs don't have the "pucks". If you use those newer versions in the recommended heat range and gap I guess the Delco would be OK.
DG
DG
Good!
I'm sneaking off in an hour to go try out my new drag pack, the air is good, cool temps!
BTW, I run TR6 plugs now, they afford a couple more degrees of timing w/o KR.
Ron
Ron
