TPS- wire off pedal?
Anybody help me find the tps signal wire off the pedal? pics or anything helps, it has to be off the pedal.
01 Z
thanks
01 Z
thanks
Mind if I ask what you are doing? Why does it NEED to be off the pedal? Most of the nitrous guys use the blue lead off the throttle body.
When people talk about the TPS they are generally referring to absolute TPS, which is calculated at the TAC on the throttle body. This is different from pedal position, as ETC pedal position and MAP are both used in determining Desired Throttle Area, (logged as ETC Desired Position, read by 3 APP sensors on pedal assembly) which is also not the same as Absolute TPS.
Jack
Its for my transmission controller for an auto swap in my Z. im running it off the TB but RPM says it has to go off the pedal to read right. not sure exactly which one by the pic
Hook it up to the pedal lol
I'm using the tcm 2000 controller from power train control solutions
Dark blue wire off pedal seems to work so far
Jack
