Part Numbers
Part Numbers
I need some help finding some part numbers. I'm at the dealership and the service representative says I need to replace the Cooling System Hose ($41.68) and the Power Steering High Pressure Hose ($67.70). Does anyone know the GM part numbers for this? The representative said the Cooling System Hose is part # 10407026 and the Power Steering High Pressure Hose is part # 26046501.
These numbers give me no results for parts.
Any help would be appreciated.
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
26046501
Item number 8
10407026 (heater inlet hose)
Item number 10
HTH
Here are some part numbers for cooling system hoses:
Radiator inlet 10229479
Radiator outlet 10229480
Surge tank inlet 10229488
Surge tank outlet 10229491
Edit:Looks like someone else beat me to the bunch...although not sure why there is a difference in the part numbers
There are actually eight hoses that make up the cooling/heater system in total
Are you trying to verify part numbers or order them somewhere else? What do you mean when you say they give you no results? I found both on GMPartsHouse, if you'd like to save a few bucks and aren't in a rush.
10407026 - $30.85
26046501 - $50.15
10407026 - $30.85
26046501 - $50.15
Premium Supporting Vendor
10407026 - $30.85
26046501 - $50.15
10407026 - $30.85
26046501 - $50.15
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Received 19,289 Likes
'20-'21-'22-'23-'24
Thanks for the diagrams and parts numbers.
