Changing Valve Springs without Valve Seals?
Old 12-31-2012, 11:20 PM
Driver220
Driver220's Avatar
Default Changing Valve Springs without Valve Seals?
Has anyone done this? I have just under 8k miles on my 02z and am going to change the springs out to 1218s, purely for preventative maintenance...since it has such low miles I was wondering how necessary it was to do the seals as well?
Old 01-01-2013, 12:17 AM
Mike94ZLT1
Mike94ZLT1's Avatar
11 years old, and they're right there...
Old 01-01-2013, 04:11 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
And super easy to replace too. Just go really easy sliding them over the valves; use a sleeve if you can. I used a 12mm 1/4" drive deep socket to press into place.
Old 01-01-2013, 08:12 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
You've got the springs off, "just for maintenance", and it takes just another 4-5 minutes per cylinder, so why not? As "Lone Star" said, just make sure to use a protective sleeve, when sliding the new seals past the grooves in the valves. Most seal kits have one of these sleeves as part of the package.
Old 01-01-2013, 10:16 AM
Driver220
Driver220's Avatar
Thanks guys! Can anyone recommend a kit to go with the 1218s? Im probably going to order off SDPARTS.com and I found the GM Kits for LS1's (I believe they will fit the LS6, correct me if Im wrong!)...
GM LS1 Valve Stem Seal Kit, 8 Intake (https://sdparts.com/details/gm-facto...parts/12533586)
GM LS1 Valve Stem Seal Kit, 8 Exhaust (https://sdparts.com/details/gm-facto...parts/12457652)
All these with the 1218s should be everything for the job, correct? (except for the spring compressor and compression tester which I have a friend loaning me)
EDIT: Im reading LS1 valve seals wont work on the LS6 or am I misinformed...
Old 01-01-2013, 10:47 AM
NukeC5
NukeC5's Avatar
Great time to do the seals! The are cheap and easy. You may kick yourself later if you develop leaky guides.
Old 01-01-2013, 01:25 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Call Brian at Brian Tooley Racing. He seems to know a lot about this stuff and can answer all your questions and ship you what you need. He was a big help when I broke a valve spring.
Old 01-01-2013, 01:28 PM
punz
punz's Avatar
St. Jude Donor '12-'13-'14-'15
BTR has a whole kit, springs, seals, seats, retainers and locks. Price not bad either. My old steel retainer weighed 19grams, the new titanium: 8 grams
http://www.briantooleyracing.com/660...retainers.html
To Changing Valve Springs without Valve Seals?
Quick Reply: Changing Valve Springs without Valve Seals?
