C5 Vendor for Sale Exclusive forum for vendors to list C5 products, services and promotions.
Cool Product for your C5!
Old 08-08-2013, 12:30 AM
pawngod
pawngod's Avatar
subscribing, to find it again easier, thanks
Old 08-13-2013, 01:13 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Cooler is better!
Old 08-26-2013, 02:04 PM
SacCityCorvette
Supporting Vendor
We offer a lot more of the top name brand products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will be glad to get back to you with quotes and do our best to save you $$$.
Thanks,
Matthew
Old 12-05-2013, 01:36 PM
Jeffwilson34
Jeffwilson34's Avatar
Warning about A4 fluid cooled by radiator
I am not sure if heat really has anything to do with it but the transmission shop said it did
At the Transmission shop I was told that there is a small weak barrier between the coolant and Transmission fluid. You do not want this barrier to fail. Mine did, he told me that it was most likely because corvettes ran a bit hotter before the fans turned on and then they cooled quickly. That eventually broke the seal. I saw steam from under the hood and being on the interstate I could not stop right away. In less than half a mile I had a red foamy mess in my coolant and the transmission started slipping bad.
It killed the transmission and required a full rebuild. I told them I would order a new radiator but they suggested a separate cooler and keep my radiator which would be cheaper. It took over half an hour with the thermostat removed and fresh water being pumped through it before it was only water coming out. Then another 15 minutes after running it in town with radiator flush cleaner added to the water.
Old 12-05-2013, 08:13 PM
SacCityCorvette
Supporting Vendor
Wow I am glad you where able to get it all fixed up. Thanks for the warning. You definitely want to keep your trans fluid cool
Old 06-17-2014, 07:57 PM
SacCityCorvette
Supporting Vendor
Same day shipping!
Old 06-18-2014, 05:30 AM
C5Natie
C5Natie's Avatar
I installed the V3 2-3 weeks ago. Im seeing cooler coolant temps by at least 20* and because of the way my intercooler is setup, the fans are also pulling cooler air through it. Great product. This is on a vortech supercharged LS3 C5.
Old 06-21-2014, 01:42 AM
CINNEMAN
CINNEMAN's Avatar
St Jude Donor '14
PM Sent. I already purchased one and have a question.
Old 06-21-2014, 07:31 PM
BABYBUGY
BABYBUGY's Avatar
I have had one the v3r for 2 years and worth every penny
cooooooolllllllll
BABYBUGY
BABYBUGY's Avatar
sts twin works great
Old 06-22-2014, 09:49 PM
Keith Richards
Keith Richards's Avatar
Ok, don't want to get stuck in traffic again without it so v2 ordered and watching the mailbox!
Old 07-07-2014, 05:04 PM
SacCityCorvette
Supporting Vendor
Thank you for your order Keith!
Old 07-25-2014, 09:04 PM
  #33
minitech
minitech's Avatar
One thing it is great for with a modified system: You unexpectedly get caught in traffic. Car is fine with some speed to cool it down but just idling it starts to heat up. Maybe overheat if you just sit there. Put on the fans by remote there and you are good to go. If it really is not cooling off pull over, run the fans while the car is off 5-10 minutes and your engine is now completely cool (Or back to usual operating temps or lower.)
Makes me think of the Woodward Cruise coming up in Detroit. "Worlds longest self inflicted traffic jam." Going 2-3 miles per hour from Detroit to Pontiac and back. The most excellent cars all around you to see as you go. Amazing rolling show. Stock Vette probably ok (But I did need to turn off to a side street and drive my mildly modified C5 in side streets to cool off) modified engine essential to have low speed cooling.
ANY track car needs to have this to cool off between track sessions. Run it a while while you wait, turn on the engine to circulate that cool radiator fluid.
Well worth it and the company service is second to none.
Old 07-26-2014, 12:31 AM
  #34
BABYBUGY
BABYBUGY's Avatar
awesome product have one for 2 years now worth every penny
Old 07-31-2014, 04:41 PM
  #35
SacCityCorvette
Supporting Vendor
Thank you minitech and BABYBUGY!
minitech,
A self inflicted traffic jam like that can also heat up the automatic trans fluid for those that have them. And since the radiator coolant is also used to cool the trans fluid on most setups the CoolIt helps cool that fluid too.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 08-05-2014, 01:06 PM
  #36
SacCityCorvette
Supporting Vendor
This is also a great upgrade for people with automatic transmissions to help keep them cool.
Old 08-06-2014, 08:03 PM
  #37
Big_George_S
Big_George_S's Avatar
I give this product a strong endorsement. Modified my car with Twin turbos and it will run on the hot side in the summer. Also track my car at times and enjoy the ability to keep the air and fluid running (electric water Pump) with the engine off.
Best money spent and you can install it in 10 minutes.
To Cool Product for your C5!
Old 08-19-2014, 11:50 PM
  #38
SacCityCorvette
Supporting Vendor
SAME DAY SHIPPING!!!
Old 08-26-2014, 08:09 PM
  #39
SacCityCorvette
Supporting Vendor
Thank you for your feedback George !!!
Old 08-26-2014, 08:10 PM
  #40
SacCityCorvette
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
Quick Reply: Cool Product for your C5!
