Make your own C5 Oil Sender relocation kit for $50
#42
I just moved my sensor to the plug in the front side of the block and used the plug I took out to plug the hole behind the intake. Then it was just running a couple of spliced wires to the new location. Cost nothing but a little time. The only difference is I'm measuring the oil pressure before the filter. I have heard the arguement about a clogged oil filter but in my 35+ years of working on cars I have never had one.
#43
I just tried ordering this stuff from Jegs today, and my total came to $70, with free shipping. Inflation I guess. Other factor was that I could not find part number 9894DBHJERL on their web site. I found the equivalent, number 799-640830 which listed for $12.
Thanks for posting this info! This will be the second time in 18 months that I'll be replacing my OPS.
DECON BLUE (09-12-2020)
#46
Will do.
But I am doing a sensor relocate this time. I bought the parts from Jegs, about $70 shipped.
This will be sensor #4
My last brass sensor lasted about 4 years in the stock location before starting to leak oil.........but the pressure readings were still correct.
#47
After doing it 3 times I would do the relocate as well. What a PITA.
#48
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent post with lots of great info. I would like to add what I did to EXTEND my vacuum line to make manifold reinstallation a lot easier and vacuum line connection a lot more secure.
I installed a FAST 90 intake manifold. I relocated the MAP sensor to the front of the manifold. The vacuum port that needed to use is on the side of the FAST 90 Manifold. SO, I found some old used nylon vacuum line and I purchases a vacuum line splicing kit from ADVANCE Auto. Its basically heat shrink with glue on the inside of the tube. I just added a 5" length of tubing and here is what it looks like:
If you have a need to either ELIMINATE the under the manifold steam piping OR add rear cross over steam vent piping to a 2001+ car, look at the mod in the background.
I purchased a 2001+ front crossover pipe. Flipped it so the nipple is facing aft and installed it where the 2001+ vent plugs use to be. I connected the front and rear with rubber tubing and a METAL "T" fitting. I had to massage the tubing down just a little to clear the FAST 90 Install.
Bill
Bill
#49
Running Guns & Moonshine
Bill
Bill
